תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    למד כיצד לשדרג ל- Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP Deskjet F4200 All-in-One Series - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Load plain paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
  1. Remove the product from its packaging.
  2. Remove all tape and tabs from the lid and from the front and back of the product, and then open the paper tray.
    איור : Remove tape from the product and open the paper tray
  3. Open the inner access door, and then remove the packing material from the inside of the product.
    איור : Open the inner access door and remove packing material
  4. Close the inner access door firmly.
      איור : Close inner access door
    1. Inner access door
Step two: Connect the power cord and adapter
The power cord and adapter are both necessary for connecting the product to an electrical outlet.
  1. Connect the adapter to the product, and then connect the power cord to the adapter.
  2. Connect the power cord to an electrical outlet.
    איור : Connect the power cord and adapter
Step three: Turn on power
Press the power button () to turn on the product.
Step four: Load plain paper
Many different types of media can be loaded into the product. To set up the product correctly, load it with plain paper. Make sure the tray is extended fully before attempting to load the paper.
  1. Pull out the input tray extension.
    איור : Pull out the input tray extension
  2. Slide the paper-width guide to its outermost position.
    איור : Slide the paper-width guide
    Slide the paper-width guide out
  3. Tap a stack of paper on its side and top or bottom on a flat surface to align the edges.
  4. Check the paper to make sure that it meets the following criteria:
    • make sure that the paper is free of rips, dust, wrinkles, and curled or bent edges.
    • make sure that all of the sheets in the stack are the same size and type.
  5. Insert the stack of paper into the input tray with the short edge first and the side to be printed on facing down. Slide the stack of paper forward until it stops.
    איור : Load the paper
    Load the paper into the product
      שים לב:
    Make sure that the product is idle and quiet when loading paper into the input tray. If the product is engaged in a task, the paper might be pushed in too far forward and cause the product to eject blank pages.
  6. Slide the paper-width guide inward until it stops at the edge of the paper. Make sure that the stack of paper fits within the input tray and is not higher than the top of the paper-width guide.
    איור : Slide the paper-width guide to fit the stack of paper
    Slide the paper-width guide to the edge of the stack of paper
Step five: Install the cartridges
Use the following steps to install the cartridges. Leave the product on for this procedure.
  1. Open the cartridge door. The carriage moves to the far right side of the product. If the carriage does not move to the right side, turn the product off, and then turn it back on.
    איור : Open the cartridge door
  2. Remove the new cartridges from the packaging, being careful to touch only the black plastic. Use the pink pull tab to remove the tape from both cartridges.
      איור : Removing the tape
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
      שים לב:
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    איור : Do not touch the contacts or ink nozzles
  3. Slide each the new cartridge at a slight upward angle into the empty slot, and gently push it until it snaps into place.
    • To install a tri-color cartridge, insert it into the left slot.
    • To install a black cartridge, insert it into the right slot.
    איור : Insert the tri-color cartridge
  4. Close the cartridge door.
    איור : Close the cartridge door
  5. The product prints a cartridge alignment sheet because it recognizes that the cartridges are new. Save this sheet to align the cartridges.
Step six: Align the cartridges
Use the alignment sheet from the previous step to align the cartridges.
  1. Lift the product lid.
  2. Place the alignment sheet on the glass so the top of the sheet is on the right side with the text facing down. Make sure the sheet is aligned with the right-front corner of the glass.
    איור : Placement of the alignment sheet on the glass
  3. Lower the product lid.
  4. Press the scan button () on the product control panel. The product aligns the cartridges.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
