תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    למד כיצד לשדרג ל- Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP Photosmart 3100, 3200, and 3300 Series All-in-One - Installing Ink Cartridges
This document contains information about installing the ink cartridges.
Install the ink cartridges
  שים לב:
Be sure to use only the ink cartridges that came with the printer. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup.
  1. Squeeze the tabs at the bottom of each latch to release it, and then lift the latch.
    איור : Opening the ink cartridge latches
  2. Lift all six latches.
    איור : All the latches open
    Insert the black ink cartridge into the far-left stall, and then lower the latch and push it in firmly until it snaps in place.
    איור : Install the black ink cartridge
    Repeat this process to install the Yellow, Light Cyan, Cyan, Light Magenta, and Magenta ink cartridges.
    איור : All the ink cartridges installed properly
    הערה:
    Match the color and pattern of the ink cartridge to the color and pattern on the carriage.
      שים לב:
    Make sure each latch is secure after installing the ink cartridge.
  3. Lower the top cover, and follow the prompts on the printer screen to begin the ink cartridge initialization.
    הערה:
    A one-time initialization process begins after ink cartridge installation. Mechanical noises during this process are normal and will last approximately five (5) minutes. Do not turn off or disconnect the product during this time.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
