16D93EA
HP ENVY Laptop - 15-ep0155nd
Intel® Core™ i5-10300H (2.5 GHz base frequency, up to 4.5 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1660 Ti with Max-Q design (6 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD, IPS, anti-glare, micro-edge, WLED-backlit, 400 nits, 100% sRGB (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0a; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.68 x 1.84 cm
2.14 kg
200 W Smart AC power adapter
6-cell, 83 Wh Li-ion polymer
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY Laptop - 15-ep0155nd Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP QuickDrop; HP Support Assistant
Pre-installed software
Netflix; ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Ireland
- ${title}
hp-hero-support-search
- ${title}
