HP Notebooks with Synaptics TouchPad - How to Disable the "Double Tap to Enable or Disable TouchPad" Feature
This document applies to HP Notebook computers with the Synaptics TouchPad.
Double-tapping the upper-left hand corner of the TouchPad enables or disables the TouchPad. When disabled, some models display a graphic on the screen showing the TouchPad with a red line through it.
TouchPad with red line through it
An amber light illuminates briefly if the computer supports this feature. There might also be an audible sound.
This document describes how to disable the Double Tap to Enable or Disable TouchPad feature.
If the option to disable the touchpad is not available, download the latest touchpad driver from Windows Update. For more information go to Updating the driver through Windows Update in this document.
Country/Region: Flag Ireland
