    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Gaming Pavilion - 17-cd0020ur Product Specifications
7GL79EA
Intel® Core™ i5 9300H (2.4 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal Full HD display
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
40.5 x 28.2 x 2.5 cm
2.77 kg
150 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
FreeDOS 1.2
Country/Region: Flag Indonesia
