Document ID: c03482879
Version: 1
NOTEBOOK - System BIOS Update F.28 for 8460w, 8460p, and 6460b
Release date : 07-Sep-2012
Last updated : 19-Sep-2012
DETAILS OF CHANGE
  • Added Max SATA Speed option in F10 BIOS Setup (Computer Setup). This will allow the user to set the maximum SATA speed to 6.0 Gbps or to 3.0 Gbps.
  • Fixed an issue where the BIOS Power On feature would not wake up the computer from the Off state in certain scenarios.
  • Fixed an intermittent issue where the optical drive tray would not open when the eject button was pressed.
  • Fixed an intermittent issue where the battery may not start to charge if it had been fully discharged.
  • Fixed an intermittent issue where some computers would not boot from Solid State Drives (SSDs).
REASON FOR CHANGE
F10 BIOS Setup (Computer Setup) quarterly refresh maintenance release.
IMPACT OF CHANGE
By default, the new F10 BIOS Setup (Computer Setup) option, "Max SATA Speed," will be set to 6.0 Gbps.
Components affected:
HP EliteBook 8460w Mobile Workstation, HP EliteBook 8460p Notebook PC, and HP ProBook 6460b Notebook PC
DATE OF CHANGE
Effective date : 20-Sep-2012
Hardware platforms affected : HP EliteBook 8460p Notebook PC, HP EliteBook 8460w Mobile Workstation, HP ProBook 6460b Notebook PC
Country/Region: Flag Indonesia
