This document is for HP Color LaserJet Pro MFP M182n, M182nw, and M183fw printers.
To replace the toner cartridge, open the toner cartridge door, remove the old toner cartridge, and then install the new toner cartridge.
megjegyzés:The imaging drum is integrated into the toner cartridge. To replace the imaging drum, you must replace the toner cartridge.
vigyázat:Do not touch the imaging drum on the bottom of the tonercartridge. Fingerprints on the imaging drum can cause print qualityproblems.![]()
