Műveletek
Betöltés...
HP ügyféltámogatás – tudásbázis
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
HP LaserJet, HP PageWide - Printers compatible with macOS Catalina 10.15, Mojave 10.14
Whether upgrading the printer driver on a macOS or installing a printer with a new macOS 10.15, use this document to make sure the printer is compatible, and that you are using an install connection that the printer supports.
This document applies to the following printer families:
  • HP LaserJet Pro
  • HP LaserJet Enterprise
  • HP LaserJet Managed
  • HP LaserJet Ultra
  • HP Officejet Enterprise
  • HP Officejet Pro X
  • HP PageWide Enterprise
  • HP PageWide Pro
  • HP PageWide Managed
For an older HP LaserJet printer, go to Older HP printers with macOS drivers.
For HP Deskjet, ENVY, OfficeJet, Photosmart, or PSC printers, go to macOS and OS X Compatible Printers.
Get the driver
The printers listed below can automatically use AirPrint, the default print path, when the printer and the Mac are connected to the same local network.2,4
To add additional features, use the HP Easy Start utility.
  • If you have previously installed the printer using HP Easy Start, launch the HP Easy Start app from the dock and follow the onscreen instructions.
  • For first-time printer installs, follow these steps:
    1. Download the HP Easy Start utility.
    2. Launch the app, select the printer, and then let the utility automatically install the driver(s) and add the print queue.3
If after installing the HP print driver in macOS Catalina (10.15) the features are not as expected, go to Print features do not work as expected or are missing in macOS Catalina (10.15).
Legend
= USB connection
= Network connection
= Wireless connection
HP LaserJet
The following list includes HP LaserJet Pro, HP LaserJet Enterprise, and HP LaserJet Managed printers compatible with macOS 10.15. They are listed by model in numerical order with the supported connection types available for install.
HP LaserJet series
Install  connection1
HP LaserJet Pro M12a Printer
HP LaserJet Pro M12w Printer
HP LaserJet M15a
HP LaserJet M15w
HP LaserJet M16a
HP LaserJet M17a
HP LaserJet M17w
HP LaserJet Pro MFP M26a5
HP LaserJet Pro MFP M26nw5
HP LaserJet MFP M28a Printer5
HP LaserJet MFP M28w Printer5
HP LaserJet series
Install  connection1
HP LaserJet Pro M101a
HP LaserJet Pro M101w
HP LaserJet Pro M102a, M102c
HP LaserJet Pro M102cw, M102w
HP LaserJet Pro M103a
HP LaserJet Pro M103w
HP LaserJet Pro M104a, M104c
HP LaserJet Pro M104cw, M104w
HP LaserJet Ultra M105a
HP LaserJet Ultra M105w
HP LaserJet Ultra M106a, M106c
HP LaserJet Ultra M106cw, M106w
HP LaserJet series
Install  connection1
HP LaserJet Pro MFP M125, M1265
HP LaserJet Pro MFP M127, M1285
HP LaserJet Pro MFP M129a5
HP LaserJet Pro MFP M129fn5
HP LaserJet Pro MFP M129fw5
HP LaserJet Pro MFP M129nw5
HP LaserJet Pro MFP M129snw5
HP LaserJet Pro MFP M130a, M130c5
HP LaserJet Pro MFP M130fn, M130cfn5
HP LaserJet Pro MFP M130fw, M130cfw5
HP LaserJet Pro MFP M130nw, M130cnw5
HP LaserJet Pro MFP M130snw, M130csw5
HP LaserJet Pro MFP M131a5
HP LaserJet Pro MFP M131fn, M131fp5
HP LaserJet Pro MFP M131fw5
HP LaserJet Pro MFP M131nw5
HP LaserJet Pro MFP M131snw5
HP LaserJet series
Install  connection1
HP LaserJet Pro MFP M132a, M132c5
HP LaserJet Pro MFP M132cfn, M132fn5
HP LaserJet Pro M132cfp, M132fp5
HP LaserJet Pro MFP M132cfw, M132fw5
HP LaserJet Pro MFP M132cnw, M132nw5
HP LaserJet Pro MFP M132csw5
HP LaserJet Ultra MFP M133a5
HP LaserJet Ultra MFP M134a, M134c5
HP LaserJet Ultra MFP M133fn5
HP LaserJet Ultra MFP M134cfn, M134fn5
HP LaserJet Pro 100 color MFP M1755
HP Color LaserJet Pro MFP M1765
HP Color LaserJet Pro MFP M1775
HP Color LaserJet Pro M180n
HP Color LaserJet Pro M180nw
HP Color LaserJet Pro M181fw
HP LaserJet Pro M201, M2025
HP LaserJet series
Install  connection1
HP LaserJet Pro M203d
HP LaserJet Pro M203dn
HP LaserJet Pro M203dw
HP LaserJet Ultra M206dn
HP LaserJet Pro MFP M2255
HP LaserJet Pro MFP M2265
HP LaserJet Pro MFP M2275
HP LaserJet Ultra MFP M230sdn5
HP LaserJet Pro MFP M230fdw5
HP LaserJet Pro 200 color Printer M251
HP Color LaserJet Pro M252
HP Color LaserJet Pro M254dw
HP Color LaserJet Pro M254dn
HP Color LaserJet Pro M254nw
HP LaserJet series
Install  connection1
HP Color LaserJet Pro MFP M2745
HP LaserJet Pro 200 color MFP M2765
HP Color LaserJet Pro MFP M2775
Color LaserJet Pro MFP M280a5
Color LaserJet Pro MFP M280nw5
Color LaserJet Pro MFP M281cdw5
Color LaserJet Pro MFP M281fdn5
Color LaserJet Pro MFP M281fdw5
HP LaserJet Pro 300 color Printer M351
HP LaserJet Pro 300 color MFP M3755
HP Color LaserJet Pro MFP M3775
HP LaserJet series
Install  connection1
HP LaserJet Pro M401
HP LaserJet Pro M402d, M402dw
HP LaserJet Pro M402dn, M402n
HP LaserJet Pro M403d, M403dw
HP LaserJet Pro M403dn, M403n
HP LaserJet Pro 400 MFP M4255
HP LaserJet Pro MFP M426a5
HP LaserJet Pro MFP M426dw, M426fdw5
HP LaserJet Pro MFP M426f, M426fdn5
HP LaserJet Pro MFP M427dw, M427fdw5
HP LaserJet Pro MFP M427f, M427fdn5
HP LaserJet series
Install  connection1
HP LaserJet Pro M435 MFP5
HP LaserJet Pro 400 color Printer M451
HP Color LaserJet Pro M452
HP LaserJet Pro 400 color MFP M4755
1
HP Color LaserJet Pro MFP M4765
HP Color LaserJet Pro MFP M4775
HP LaserJet Pro M501
HP LaserJet Enterprise M506
HP LaserJet Managed M506 MFP5
HP LaserJet Enterprise M507
HP LaserJet Pro MFP M521
HP LaserJet series
Install  connection1
HP LaserJet Enterprise 500 MFP M525
HP LaserJet Managed MFP M525
HP LaserJet Enterprise flow MFP M525c
HP LaserJet Enterprise MFP M527
HP LaserJet Managed MFP M527
HP LaserJet Enterprise MFP M528
HP LaserJet Enterprise 500 color M551
HP Color LaserJet Enterprise M552
HP Color LaserJet Enterprise M553
HP Color LaserJet Managed M553
HP LaserJet Pro 500 color MFP M5705
HP LaserJet series
Install  connection1
HP Color LaserJet Managed MFP M575
HP LaserJet Enterprise 500 color MFP M575
HP Color LaserJet Managed MFP M577
HP Color LaserJet Enterprise MFP M577
HP Color LaserJet Enterprise Flow MFP M577z
HP LaserJet Enterprise M601
HP LaserJet Enterprise M602
HP LaserJet Enterprise M603
HP LaserJet Enterprise M604
HP LaserJet Enterprise M605
HP LaserJet Managed M605
HP LaserJet Enterprise M606
HP LaserJet series
Install  connection1
HP LaserJet Enterprise M607
HP LaserJet Enterprise M608
HP LaserJet Enterprise M609
HP LaserJet Enterprise MFP M630
HP LaserJet Enterprise Flow MFP M630z
HP LaserJet Managed MFP M630
HP LaserJet Enterprise MFP M631
HP LaserJet Enterprise MFP M632
HP LaserJet Enterprise MFP M633
HP Color LaserJet Enterprise M651
HP Color LaserJet Managed M651
HP Color LaserJet Enterprise 652
HP LaserJet series
Install  connection1
HP Color LaserJet Enterprise 653
HP Color LaserJet Enterprise MFP M680
HP Color LaserJet Enterprise Flow MFP M680z
HP Color LaserJet Managed MFP M680
HP Color LaserJet Enterprise MFP 681
HP Color LaserJet Enterprise MFP 682
HP LaserJet Pro M701
HP LaserJet Pro M706
HP LaserJet Enterprise 700 M712
HP LaserJet Enterprise MFP M725
HP LaserJet Managed MFP M725
HP Color LaserJet Enterprise M750
HP LaserJet series
Install  connection1
HP Color LaserJet Enterprise M751
HP LaserJet Enterprise 700 color MFP M775
HP Color LaserJet Managed MFP M775
HP Color LaserJet Enterprise MFP M776
HP LaserJet Enterprise M806
HP LaserJet Enterprise flow MFP M830
HP LaserJet Managed flow MFP M830
HP Color LaserJet Enterprise M855
HP Color LaserJet Enterprise M856
HP Color LaserJet Enterprise flow MFP M880
HP Color LaserJet Managed flow MFP M880
HP LaserJet series
Install  connection1
HP Color LaserJet Pro CP1020
HP Color LaserJet Pro CP1025
HP Color LaserJet Pro CP1027
HP Color LaserJet Pro CP1028
HP LaserJet Pro CM1410 Color MFP5
HP LaserJet Pro CM1415 Color MFP5
HP Color LaserJet Pro CP1525
HP Color LaserJet Pro CP1525nw
HP LaserJet Pro M1530 MFP5
HP LaserJet Pro M1536 MFP5
HP Color LaserJet Enterprise CM4540 MFP
HP LaserJet Enterprise M4555 MFP
HP Color LaserJet Enterprise CP5220
HP Color LaserJet Enterprise CP5225
HP Color LaserJet Enterprise CP5520
HP Color LaserJet Enterprise CP5525
HP Color LaserJet Managed E50040
HP LaserJet Managed E50045
HP LaserJet Managed E50145
HP LaserJet series
Install  connection1
HP LaserJet Managed MFP E52545
HP Color LaserJet Managed Flow MFP E52545
HP LaserJet Managed MFP E52645
HP Color LaserJet Managed MFP E57540
HP Color LaserJet Managed Flow MFP E57540
HP LaserJet Managed E60055
HP LaserJet Managed E60065
HP LaserJet Managed E60075
HP LaserJet Managed E60155
HP LaserJet Managed E60165
HP LaserJet Managed E60175
HP LaserJet series
Install  connection1
HP LaserJet Managed MFP E62555
HP LaserJet Managed MFP E62565
HP LaserJet Managed Flow MFP E62565z
HP LaserJet Managed MFP E62575
HP LaserJet Managed Flow MFP E62575z
HP LaserJet Managed MFP E62655
HP LaserJet Managed MFP E62665
HP LaserJet Managed MFP E62675
HP Color LaserJet Managed E65050
HP Color LaserJet Managed E65060
HP Color LaserJet Managed E65150
HP Color LaserJet Managed E65160
HP Color LaserJet Managed MFP E67550
HP Color LaserJet Managed MFP E67560
HP Color LaserJet Managed Flow MFP E67560z
HP LaserJet series
Install  connection1
HP Color LaserJet Managed MFP E67650
HP Color LaserJet Managed MFP E67660
HP LaserJet Managed MFP E72425-E72430
HP LaserJet Managed MFP E72520-E72540
HP LaserJet Managed Flow MFP E72520-E72540z
HP LaserJet Managed MFP E72525-E72535
HP Color LaserJet Managed MFP E77822-E77830
HP Color LaserJet Managed Flow MFP E77820-E77830z
HP LaserJet Managed MFP E82540-E82560
HP LaserJet Managed Flow MFP E82540z
HP LaserJet Managed MFP E82540du-E82560du
HP Color LaserJet Managed E85055
HP Color LaserJet Managed MFP E87640-E87660
HP Color LaserJet Managed Flow MFP E87640-E87660z
HP Color LaserJet Managed MFP E87640du-E87660du
HP Officejet Enterprise series
Install  connection1
HP Officejet Enterprise Color X555
HP Officejet Enterprise Color MFP X585
HP Officejet Enterprise Color Flow MFP X585
HP PageWide Enterprise series
Install  connection1
HP PageWide Enterprise Color 556
HP PageWide Enterprise Color MFP 586
HP PageWide Enterprise Color Flow MFP 586
HP PageWide Enterprise Color 755
HP PageWide Enterprise Color 765
HP PageWide Enterprise Color MFP 774
HP PageWide Enterprise Color MFP 779
HP PageWide Managed Color MFP P779
HP PageWide Enterprise Color MFP 780
HP PageWide Enterprise Color MFP 785
HP PageWide Enterprise Color Flow MFP 785
HP LaserJet series
Install  connection1
HP PageWide Managed Color E55650
HP PageWide Managed Color MFP E58650
HP PageWide Managed Color Flow MFP E58650z
HP PageWide Managed Color E75160
HP Color LaserJet Managed E75245
HP PageWide Managed Color P75250
HP Color LaserJet Managed MFP E77422-E77428
HP PageWide Managed Color MFP P77440
HP PageWide Managed Color MFP E77650-E77660
HP PageWide Managed Color Flow MFP E77650-E77660
HP PageWide Managed Color MFP P77940
HP PageWide Managed Color MFP P77950
HP PageWide Managed Color MFP P77960
For an older HP LaserJet printer, the driver for 10.15 might be available on HP.com or it might not be supported. Check the list of Older HP printers with MacOS drivers.
The AirPrint-capable printers in this document are also compatible with other cloud printing and mobile solutions. To view a list of available print solutions, go to www.hp.com/go/LaserJetMobilePrinting.
For information on how to configure scanning, go to HP LaserJet MFP - Scan in OS X and newer.
Footnotes
Footnotes
1
Some printers have wireless accessories which will enable wireless printing. Go to Printers that can use the HP 1200w NFC/Wireless Mobile Print Accessory.
2
In OS X v10.12 and newer, the default driver will automatically use AirPrint when printing.
3
The HP Easy Start utility includes fax and/or scan drivers, and advanced HP features such as custom paper size or orientation options.
4
AirPrint also provides basic fax (F) or scan (S) capability in OS  X Yosemite 10.10 or newer.
5
Download and install HP Easy Scan from the Mac App Store by clicking the App Store icon in the Dock. HP Easy Scan is compatible with El Capitan 10.11 and newer, and is the recommended scanning application for this HP LaserJet printer.
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
Ország/térség: Flag Magyarország
Műveletek
Betöltés...
