This document is for HP Ink Tank 310, 311, 315, 316, 318, 319, Wireless 410, 411, 412, 415, 416, 418, and 419 printers.
To set up a printer for the first time, remove the printer and packing materials from the box, connect the power cable, fill the ink tanks, install the printheads, load paper into the input tray, align the printheads, prime the ink system, and then install the printer software.
megjegyzés:If you are looking for the printer software, go to:
Ink Tank 310 Printer Series: 123.hp.com/IT310 Ink Tank Wireless 410 Printer Series: 123.hp.com/IT410
