This document is for the following printers:
HP Deskjet Ink Advantage 4645 e-All-in-One Printer
HP Officejet 4632 e-All-in-One Printer
HP Deskjet Ink Advantage 4646 e-All-in-One Printer
HP Officejet 4634 e-All-in-One Printer
HP Deskjet Ink Advantage 4648 e-All-in-One Printer
HP Officejet 4635 e-All-in-One Printer
HP Officejet 4630 e-All-in-One Printer
HP Officejet 4636 e-All-in-One Printer
HP Officejet 4631 e-All-in-One Printer
HP Officejet 4639 e-All-in-One Printer
To set up a printer for the first time, unpack the printer, connect the power cable, set your preferences, load paper into the input tray, and then install the ink cartridges.
megjegyzés:If you are looking for the printer software, go to:
Printer software for HP Officejet 4630 printers: http://123.hp.com/OJ4630 Printer software for HP Deskjet Ink Advantage 4640 printers: http://123.hp.com/DJ4640
