Műveletek
Betöltés...
HP ügyféltámogatás – tudásbázis
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
HP Printers - Driver and software support for Windows 7
Use this document to find the recommended HP Printer drivers for Windows 7. After determining the correct driver, click the link in the Recommended solution column to go to either a related support document with instructions or to www.hp.com/go/support to download the driver.
This document applies to the following printers:
  • HP LaserJet
  • HP LaserJet Pro
  • HP LaserJet Enterprise
  • HP LaserJet Managed
  • HP OfficeJet Enterprise
  • HP OfficeJet Managed
  • HP PageWide Enterprise
  • HP PageWide Managed
For other HP printer models, such as a Deskjet, OfficeJet Pro, or Photosmart, go to Windows 7 Compatible Printers.
HP Color LaserJet
Legend
Availability
Connection type
= Not available
= Available
= Available with limitations
= USB connection
= Network connection
= Wireless connection
N/A = Does not apply
HP Color LaserJet - Supported software and drivers
Series/model numbers
Windows 7
Compatibility requirements
Desktop and Laptop
Administrators
HP LaserJet series
PC support
Install connection9
Scan connection10
Scan/Send solution11
Other Windows 7 solutions2
Color LaserJet Family (original printer)
N/A
N/A
Color LaserJet 5
N/A
N/A
Color LaserJet 5m
N/A
N/A
100/M175 MFP
170/
M176 MFP
M177 MFP
200/M251
N/A
N/A
M252
N/A
N/A
M274 MFP
9
200/M276 MFP
HP LaserJet series
PC support
Install connection9
Scan connection10
M277 MFP
300/M351
LJ 300-400
N/A
N/A
300/M375 MFP
LJ 300-400
M377 MFP
9
400/M451
LJ 300-400
N/A
N/A
M452
N/A
N/A
M454dn
N/A
N/A
M454dw
M454nw
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
400/M475 MFP
LJ 300-400
M476 MFP
M477 MFP
9
MFP M479
9
HP LaserJet series
PC support
Install connection9
Scan connection10
500/M551
N/A
N/A
M552
N/A
N/A
M553
N/A
N/A
500/M570 MFP
500/M575 MFP
EWS12 or Control panel
500/M575c flow MFP
M577 MFP
M577z flow MFP
9
M651
N/A
N/A
M652
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
M653dh
M653dn
N/A
N/A
M653x
N/A
N/A
M680 MFP
MFP M681
EWS13 or Control panel
MFP M682z
M750
N/A
N/A
M751
N/A
N/A
700/M775 MFP
MFP M776dn
MFP M776z
MFP M776zs
M855
N/A
N/A
M856
N/A
N/A
M880 flow MFP
HP LaserJet series
PC support
Install connection9
Scan connection10
1500
N/A
N/A
1600
1
N/A
N/A
2500
N/A
N/A
UPD4,7
2550
N/A
N/A
UPD4,7
2600n
N/A
N/A
2605
UPD4,7
N/A
N/A
2700
UPD4,7
N/A
N/A
3000
UPD4,7
N/A
N/A
3500
1
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
3550
1
N/A
N/A
3600
1
N/A
N/A
3700
UPD4,7
N/A
N/A
3800
UPD4,7
N/A
N/A
4500
UPD4,7
N/A
N/A
4550
UPD4,7
N/A
N/A
4600
UPD4,7
N/A
N/A
4610n
UPD4,7
N/A
N/A
4650
UPD4,7
N/A
N/A
4700
UPD4,7
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
4730 MFP
UPD4,7
5500
UPD4,7
N/A
N/A
5550
UPD4,7
N/A
N/A
8500
N/A
N/A
8550 MFP
8550
N/A
N/A
9085mfp
9500
UPD4,7
N/A
N/A
9500 MFP
UPD4,7
9850mfp
CM1015 MFP
CM1017 MFP
UPD4,7
CM1312 MFP
UPD4,7
In OS2
CM1410
CM1415 MFP
CM2320 MFP
UPD4,7
In OS2
CM3530 MFP
UPD4,7
HP LaserJet series
PC support
Install connection9
Scan connection10
CM4540 MFP
CM4730 MFP
UPD4,7
CM6030 MFP
UPD4,7
CM6040 MFP
UPD4,7
CM8000 MFP
CM8050 MFP
CM8060 MFP
(Edgeline)
UPD4,7
CP1020
CP1025
N/A
N/A
CP1210
CP1213
CP1214
CP1215
CP1216
CP1217
N/A
N/A
CP1510
CP1514
CP1515
CP1518
UPD4,7
N/A
N/A
CP1520
CP1525
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
CP2025
UPD4,7
N/A
N/A
CP3505
UPD4,7
N/A
N/A
CP3520
CP3525
UPD4,7
N/A
N/A
CP4005
UPD4,7
N/A
N/A
CP4020
CP4025
64-bit
N/A
N/A
CP4520
CP4525
64-bit
N/A
N/A
CP5220
CP5225
UPD4,7
N/A
N/A
CP5520
CP5525
N/A
N/A
CP6015
UPD4,7
N/A
N/A
HP LaserJet (mono)
Legend
Availability
Connection type
= Not available
= Available
= USB connection
HP LaserJet (mono) - Supported software and drivers
Windows 7
Desktop and Laptop
Administrators
HP LaserJet series
PC support
Install connection9
Scan connection10
LaserJet
Plus
N/A
N/A
LaserJet
Printer Family (original printer)
Serial port15
N/A
N/A
II
N/A
N/A
IId
N/A
N/A
IIp / IIp Plus
Serial or Parallel port15
N/A
N/A
IIId
N/A
N/A
III / IIIp
N/A
N/A
IIIsi
N/A
N/A
4 / 4 Plus
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
4LC / 4LJ
N/A
N/A
4L / 4mL
Parallel port15
N/A
N/A
4m / 4m Plus
N/A
N/A
4mp / 4p
N/A
N/A
4si / 4si   mx
4mv / 4v
N/A
N/A
5
N/A
N/A
5m / 5n
N/A
N/A
5L
5mp / 5p
Parallel port15
N/A
N/A
5L Extra
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
5se
N/A
N/A
5si / 5si  mx
N/A
N/A
5si mopier
6L / 6mp / 6p
N/A
N/A
6L Pro
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
100/
M125 MFP
M126 MFP
M127 MFP
M128 MFP
M201
N/A
N/A
M202
N/A
N/A
M225 MFP
M226 MFP
M275
(Topshot)
240 mopier
HP LaserJet series
PC support
Install connection9
Scan connection10
M304a
N/A
N/A
M305d
N/A
N/A
M305dn
N/A
N/A
320 mopier
MFP M329dn
MFP M329dw
HP LaserJet series
PC support
Install connection9
Scan connection10
400/M401
N/A
N/A
M402d
M402dw
N/A
N/A
M402dn
M402n
N/A
N/A
M403d
M403dw
N/A
N/A
M403dn
M403n
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
M404dn
M404n
N/A
N/A
M404dw
N/A
N/A
M405d
N/A
N/A
M405dn
M405n
N/A
N/A
M405dw
N/A
N/A
400/M425 MFP
M426dw MFP
M426fdn
M426fdw MFP
HP LaserJet series
PC support
Install connection9
Scan connection10
M427dw MFP
M427fdn MFP
M427fdw MFP
MFP M428dw
MFP M428fdn
MFP M428fdw
HP LaserJet series
PC support
Install connection9
Scan connection10
MFP M429dw
MFP M429fdn
MFP M429fdw
MFP M433
400/M435 MFP
MFP M436dn
MFP M436n
MFP M436nda
HP LaserJet series
PC support
Install connection9
Scan connection10
MFP M437dn
MFP M437n
MFP M437nda
MFP M438dn
MFP M438n
MFP M438nda
MFP M439dn
MFP M439n
MFP M439nda
MFP M440dn
MFP M440n
MFP M440nda
MFP M442dn
MFP M443nda
500 Plus
M501
N/A
N/A
M506
9
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
M507dn
M507n
9
N/A
N/A
M507x
N/A
N/A
M521 MFP
500/M525 MFP
500/M525c flow MFP
M527 MFP
M527z flow MFP
9
MFP M528dn
MFP M528f
MFP M528z
HP LaserJet series
PC support
Install connection9
Scan connection10
600/M601
N/A
N/A
600/M602
N/A
N/A
600/M603
N/A
N/A
M604
N/A
N/A
M605
N/A
N/A
M606
N/A
N/A
M607
N/A
N/A
M608
N/A
N/A
M609
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
M610
N/A
N/A
M611
N/A
N/A
M612
N/A
N/A
M630 MFP
M630 flow MFP
M701
N/A
N/A
M706
N/A
N/A
700/M712
N/A
N/A
700/M725 MFP
M806
N/A
N/A
M830 flow MFP
flow MFP M830z NFC/Wireless Direct
1000
N/A
N/A
1005
N/A
N/A
1010
N/A
N/A
1012
N/A
N/A
1015
1
N/A
N/A
1018
1
N/A
N/A
1020
1
N/A
N/A
1022
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
1100
N/A
N/A
1150
1
N/A
N/A
1160
1
N/A
N/A
1200
UPD4,7
N/A
N/A
1300
UPD4,7
N/A
N/A
1320
UPD4,7
1
N/A
N/A
2000
N/A
N/A
2100
UPD4,7
N/A
N/A
2200
UPD4,7
N/A
N/A
2300
UPD4,7
N/A
N/A
2300L
UPD4,7
1
N/A
N/A
2400/2410
UPD4,7
1
N/A
N/A
2420
2430
UPD4,7
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
3300 MFP
3320n MFP
UPD4,7
3300 MFP
3310 MFP
3330 MFP
1
1
4000
N/A
N/A
4050
4050se
4050t
UPD4,7
N/A
N/A
4050n
4050tn
UPD4,7
N/A
N/A
4100
UPD4,7
N/A
N/A
4100 MFP
4101 MFP
UPD4,7
4200
4200L
UPD4,7
N/A
N/A
4240 / 4240n
UPD4,7
N/A
N/A
4250
UPD4,7
N/A
N/A
4300
UPD4,7
N/A
N/A
4345 MFP
UPD4,7
4350
UPD4,7
N/A
N/A
5000
UPD4,7
N/A
N/A
5100
UPD4,7
N/A
N/A
5200
UPD4,7
N/A
N/A
5200L / 5200LE
UPD4,7
1
N/A
N/A
5200 LX
UPD4,7
1
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
8000
UPD4,7
N/A
N/A
8000 MFP
UPD4,7
8100
UPD4,7
N/A
N/A
8100 MFP
UPD4,7
8150
UPD4,7
N/A
N/A
8150 MFP
UPD4,7
9000
UPD4,7
N/A
N/A
9000 MFP
9000L MFP
UPD4,7
9040
UPD4,7
N/A
N/A
9050
UPD4,7
N/A
N/A
9040 MFP
9050 MFP
UPD4,7
9055mfp
UPD4,7
9065mfp
UPD4,7
M1005 MFP
1
1
M1120 MFP
HP LaserJet series
PC support
Install connection9
Scan connection10
M1132 MFP
M1132s MFP
M1136 MFP
M1210 MFP
M1212 MFP
M1213 MFP
M1219 MFP
M1214 MFP
M1216 MFP
M1217 MFP
M1218 MFP
M1319 MFP
1
1
M1522 MFP
UPD4,7
In OS2
M1530 MFP
M1536 MFP
M2727 MFP
UPD4,7
In OS2
HP LaserJet series
PC support
Install connection9
Scan connection10
M3027 MFP
UPD4,7
M3035 MFP
UPD4,7
M4345 MFP
UPD4,7
M4555 MFP
M5025 MFP
UPD4,7
M5035 MFP
UPD4,7
M9040 MFP
M9050 MFP
UPD4,7
HP LaserJet series
PC support
Install connection9
Scan connection10
P1000
P1005
1
N/A
N/A
P1006
1
N/A
N/A
P1007
1
N/A
N/A
P1008
1
N/A
N/A
P1100
P1102
P1102s
N/A
N/A
P1102w
N/A
N/A
P1104
P1106
P1107
P1108
P1109
1
N/A
N/A
P1500
P1505
P1505n
N/A
N/A
P1560/
P1566
P1567
P1568
P1569
N/A
N/A
P1600/
P1606
P1607
P1608
P1609
N/A
N/A
HP LaserJet series
PC support
Install connection9
Scan connection10
P2010
P2014
1
N/A
N/A
P2014n
N/A
N/A
P2015
P2015d
UPD4,7
1
N/A
N/A
P2015dn
P2015n
P2015x
UPD4,7
N/A
N/A
P2035
1
N/A
N/A
P2050
P2055
N/A
N/A
UPD4,7
In OS2
P3004
P3005
UPD4,7
N/A
N/A
P3011
P3015
UPD4,7
N/A
N/A
P4010
P4014
UPD4,7
N/A
N/A
P4015
UPD4,7
N/A
N/A
P4510
P4515
UPD4,7
N/A
N/A
MFP M42523dn
MFP M42523n
MFP M42525dn
MFP M42525n
MFP M42623dn
MFP M42623n
MFP M42625dn
MFP M42625n
MFP M72625dn
MFP M72630dn
HP LaserJet Managed
Legend
Availability
Connection type
= Not available
= Available
= USB connection
HP LaserJet Managed - Supported software and drivers
Windows 7
Desktop and Laptop
Administrators
HP LaserJet Managed series
PC  support
Install  connection9
Scan  connection10
Managed M506dnm
N/A
N/A
Managed M506xm
N/A
N/A
PCL6 driver - no installer5,15,16,195,15,16,193,5,7,19
Windows Update2,12,19
In OS
Managed Flow MFP M525cm
Managed MFP M525fm
PCL6 driver5,17,19
In OS
Managed Flow MFP M527cm
Managed MFP M527dnm
PCL6 driver5,17,19
In OS
Managed M553dnm
N/A
N/A
In OS
Managed M553xm
N/A
N/A
In OS
Managed Flow MFP M575cm
Managed MFP M575dnm
PCL6 driver5,17,19
In OS
Managed Flow MFP M577cm
Managed MFP M577dnm
PCL6 driver5,17,19
In OS
PC  support
Install  connection9
Scan  connection10
Managed M605dnm
N/A
N/A
Managed M605xm
N/A
N/A
Managed MFP M630hm
Managed Flow MFP M630hm
Managed Flow MFP M630zm
PCL6 driver5,17,19
In OS
Managed M651dnm
Managed M651xhm
N/A
N/A
Managed MFP M680dnm
Managed MFP M680zm
PCL6 driver5,17,19
In OS
Managed MFP M775fm
Managed MFP M775zm
PCL6 driver5,17,19
In OS
Managed Flow MFP M830zm
PCL6 driver5,17,19
In OS
Managed Flow MFP M880zm
Managed Flow MFP M880zm+
PCL6 driver5,17,19
In OS
PC  support
Install  connection9
Scan  connection10
E50045dn
N/A
N/A
E50145
N/A
N/A
MFP E52545
MFP E52645
E55040dn
N/A
N/A
MFP E57540
E60055
N/A
N/A
E60065
N/A
N/A
E60075
N/A
N/A
PC  support
Install  connection9
Scan  connection10
E60155
N/A
N/A
E60165
N/A
N/A
E60175
N/A
N/A
MFP E62555
MFP E62565
MFP E62575
MFP E62655
MFP E62665
Flow MFP E62665
MFP E62675
Flow MFP E62675
PC  support
Install  connection9
Scan  connection10
E65050
N/A
N/A
E65060
N/A
N/A
E65150
N/A
N/A
E65160
N/A
N/A
MFP E67550
MFP E67560
MFP E67650
MFP E67660
MFP E72425
MFP E72430
PC  support
Install  connection9
Scan  connection10
MFP E72525
MFP E72530
MFP E72535
E75245
N/A
N/A
MFP E77422
MFP E77428
MFP E77822
MFP E77825
MFP E77830
MFP E78223
MFP E78228
MFP E78323
MFP E78325
MFP E78330
MFP E82540
MFP E82550
MFP E82560
MFP E82540du
MFP E82550du
MFP E82560du
PC  support
Install  connection9
Scan  connection10
E85055
N/A
N/A
MFP E87640
MFP E87650
MFP E87660
MFP E87640du
MFP E87650du
MFP E87660du
HP LaserJet All-in-Ones
Legend
Availability
Connection type
= Not available
= Available
= USB connection
megjegyzés:
While most LaserJet printers support network scanning, the following printers do NOT support scanning via a network, do NOT support the Scan to PDF feature, and do not support utilities such as HP Solution Center in Windows 7.
HP LaserJet All-in-Ones - Supported software and drivers
Windows 7
Desktop and Laptop
Administrators
HP LaserJet series
PC  support
Install  connection9
Scan  connection10
3015
3020
3030
32/64-bit
32/64-bit
UPD4,7
64-bit
64-bit
3050
3052
3055
32-bit
32-bit
HP Scan software
UPD4,7
In OS2
64-bit
64-bit
UPD4,7
32/64-bit
32/64-bit
3380
32/64-bit
32/64-bit
3390
3392
32-bit
32-bit
HP Scan software
64-bit
64-bit
UPD4,7
32/64-bit
32/64-bit
Legend
Availability
Connection type
= Not available
= Available
= USB connection
HP OfficeJet Enterprise - Supported software and drivers
Windows 7
Desktop, Laptop, and Tablet
Administrators
HP OfficeJet series
PC  support
Install  connection9
Scan  connection10
X555
N/A
N/A
MFP X585
Flow MFP X585
Legend
Availability
Connection type
= Not available
= Available
= USB connection
HP OfficeJet Managed - Supported software and drivers
Windows 7
Administrators
PC  support
Install  connection9
Scan  connection10
Managed MFP X585dnm
Managed Flow MFP X585zm
Legend
Availability
Connection type
= Not available
= Available
= USB connection
HP PageWide Enterprise - Supported software and drivers
Windows 7
Administrators
PC  support
Install  connection9
Scan  connection10
556
9
N/A
N/A
MFP 586
Flow MFP 586z
9
755
9
N/A
N/A
PCL6 driver5,16,18
PCL6 driver - no installer5,14,15,18
UPD3,5,7,18
765
9
N/A
N/A
UPD3,5,7,18
MFP 774
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP 779
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP 780
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP 785f
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP 785z+
MFP 785zs
PCL6 driver5,16,18
UPD3,5,7,18
HP PageWide Managed
Legend
Availability
Connection type
= Not available
= Available
= USB connection
HP PageWide Managed - Supported software and drivers
Windows 7
Desktop and Laptop
Administrators
HP PageWide Managed
PC  support
Install  connection9
Scan  connection10
E55650
9
N/A
N/A
PCL6 driver5,16,18
UPD3,5,7,18
MFP E58650
MFP Flow E58650
9
PCL6 driver5,16,18
UPD3,5,7,18
E75160
9
N/A
N/A
PCL6 driver5,16,18
UPD3,5,7,18
P75250
9
N/A
N/A
PCL6 driver5,16,18
UPD3,5,7,18
MFP P77440
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP E77650
MFP E77660
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP P77940
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP P77950
9
PCL6 driver5,16,18
UPD3,5,7,18
MFP P77960
9
PCL6 driver5,16,18
UPD3,5,7,18
Driver and software types
Some printers have multiple driver options for use depending on the environment, printer connection type, and availability:
  • Full solution – The Full solution is custom drivers and/or software created for select printers. "HP Full feature software and driver," "HP Full feature driver," or "HP Full software and drivers," offer a complete solution including full printer software functionality and the most advanced features available for the printer, and does not require additional HP software. Recommended where available, the Full solution is either included on the HP Windows 7 CD/DVD that came with a new printer or is available for download from www.hp.com/go/support. Can be installed via USB or network.
  • Basic PCL6 driver – PCL6 drivers use the printer's resources (internal processor and memory) to process print commands. It is a custom driver created for select printers that support PCL 6. Should not be confused with the UPD PCL 6. This download, available only from www.hp.com/go/support, can be used to provide basic print or print/scan software features. Enables more advanced software functionality than the drivers included In-OS or Windows Update. Can be installed via USB or network.
  • Basic Host-based – Host-based drivers use the computer's (host's) resources to process print commands when the computer is connected to the printer via USB cable. It is a custom driver created for host-based printers to provide basic print or print/scan software features. Enables more advanced software functionality than the drivers included In-OS or Windows Update. Similar to the Basic PCL6 driver, this driver is available only from www.hp.com/go/support. Also known as a Plug and Play driver because it can be installed via USB only.
  • Plug and Play driver or package – Host-based driver that can be installed via USB only. Similar to the Basic Host-based option, this driver is available only from www.hp.com/go/support.
  • Universal Print Driver (UPD) – Universal driver download for use by customers that require print-only software features or for use by system administrators that want to use the file for distribution. Includes PCL 6, PCL5, and PostScript versions. Not recommended for All-in-One printers. Often used in a business environment by administrators or IT staff when printing via a managed print server to multiple printer models in a static or mobile print environment. Can be installed via USB or network, but is typically installed via network.
    megjegyzés:
    The HP Universal Print Driver for Windows PCL6 is recommended for most printing needs. It is used for general office applications such as word processing or spreadsheet applications, etc. HP Universal Print Driver for Windows PCL6 is recommended to achieve backward compatibility.
    The printer must have PostScript (PS) printing capability to use the HP Universal Print Driver for Windows PostScript. Use the PostScript version for the following:
    • When using a PostScript printer
    • When printing from Adobe or other highly graphic intensive applications
    • When printing documents containing a significant number of graphics or macros
    • When printing in a mixed environment, for example, printing from both Windows and Macintosh applications
  • Windows Update – Basic, driver included in Windows Update for the Windows 7 operating system (OS). For most printers, this driver provides print-only functionality (no scan features). Select printers will also have basic WIA support. Use Devices and Printers to run Windows Update and obtain the latest drivers and updates. Best used when no other solution is available to provide limited print-only software features.
  • In-Operating System (In-OS) – Basic, print-only (no scan) driver included in the Windows 7 operating system (OS) to provide limited print software features. Some of the advanced features may not be available. For some printers, these are the only driver options available. Best used when unable to connect to the internet or when no other solution is available. In the case of All-in-One printers, this is considered a better choice than UPD.
  • Point and print driver bundle – Typically used by administrators or IT staff to allow for Point and Print interaction among different operating systems. Can be used to install a shared driver on a network print server and then to point to the print server share from a network client.
    megjegyzés:
    This option is available to Enterprise customers but is not listed in this document. For more information about Point and Print driver bundles, go to www.hp.com/go/upd.
  • HP ePrint software – HP ePrint software provides the ability to wirelessly print from a Windows or Mac desktop or laptop, to any wireless direct printer that is ePrint-enabled and connected to a network or HP cloud, from within applications using the standard File > Print method. Includes a driver for Windows and a .pdf workflow for Mac. Use ePrint software to print documents or photos over the Internet by sending an email from an email-capable device, from any location, to an email address assigned to a Web-connected HP printer. Use HP ePrint App to capture, edit, and wirelessly print photos and other image files from an iPad, iPhone, iPod Touch, Android phone, or other smart phone to a wireless network-connected HP printer.
Footnotes
Footnotes
Footnote reference number
Footnote information
1
No network support. Use a USB connection to scan and/or install.
2
Internet connection required. If no internet access, use the driver included in the Windows 7 operating system (In OS) (if available). To manually install this option, use the Add Printer wizard. For instructions, go to Install the driver included in Windows or Windows Update.
3
If the company restricts access to the internet or Windows Update, contact the system administrator.
4
Universal Print Driver (UPD) provides print-only (no scan or fax) support. UPD includes an installer that enables either a traditional or dynamic mode install.
5
Full feature drivers or Full solutions are larger file downloads. When using a dial up connection, consider downloading the Basic, PLC6, Host-based, or Plug and Play option if available, or order the solution on CD if available. To check, click the link in the Recommended solution column for the printer.
6
This printer is fully supported using the recommended solution which provides print and scan software.
7
UPD is supported in Windows 7 including UPD PCL 6, UPD PCL 5, and UPD PostScript. For the best printing experience, download the latest version with the most recent fixes and features from www.hp.com/go/upd.
8
HP ePrint software is not supported via USB connections. For more information about compatibility and available mobile solutions, go to www.hp.com/go/LaserJetMobilePrinting.
9
To install the driver, connect the printer to the computer using a supported connection type. Some printers do not support network or wireless installs. For these printers, use a USB connection. Select printers have wireless accessories which will enable a wireless install.
10
To scan, connect the printer to the computer using a supported connection type. Some printers do not support wireless scanning or scanning over a network. For these printers, use a USB connection. Select printers might have wireless accessories which will enable wireless scanning.
11
Fax capability is available for select printers only. Use the HP PC Send Fax Driver or the HP LaserJet MFP Wizard Console where available.
12
Use the Embedded Web Server (EWS) to enable and configure scan features.
13
For a network installation, use the TCP/IP option.
14
The Basic driver is a PCL 6 Print driver or PCL 6 Print and Scan driver. In some cases, this does not include an installer (driver only). If after you download and double-click the file an installer does not automatically launch, install the print driver using the Add Printer Wizard.
Parallel and Serial ports are supported in Windows 7.
16
The Color LaserJet 5 and 5M only have a Postscript driver available. The Color LaserJet 5M uses the PostScript (PS) language for printing and has a PS language module installed. The Color LaserJet 5 did not have the PS language module installed but did have an optional module available. The Postscript driver will not work with the Color LaserJet 5 unless it has the optional PS language module installed. For color printing on a Color LaserJet 5, consider searching the Web for a PostScript module for this printer, and then obtain the driver from Windows Update.
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
Ország/térség: Flag Magyarország
Műveletek
Betöltés...
