Műveletek
Betöltés...
HP ügyféltámogatás – tudásbázis
Műveletek
Betöltés...
Műveletek
Betöltés...
  • Visszajelzés
Műveletek
Betöltés...
HP Printers - Set Up an HP Smart Website Account
This document is for HP printers that support web-connected printing services.
If you are unable to register your printer to your account, or you want to set up a new account with HP, visit the HP Smart website and register your printer. Registering allows you to access additional web printing services, such as HP ePrint and HP Instant Ink.
If you are setting up HP Smart for the first time, you must create or sign in to an HP account.
If you update to the latest version, you do not have to create or sign in to an HP account except in these cases:
  • You install an HP+ printer.
  • You install HP Smart on a new device, or you remove and reinstall the app.
megjegyzés:
The HP Smart website availability depends on your country/region. To see if the website is available for your country/region, go to HP Smart, and then select the country/region and language menu.
If you registered with the HP Smart website during printer setup, your printer might already be added. Go to HP Smart, and then sign in to your account.
  • If your printer is listed, skip to Setting up web-connected printing services.
  • If you have an HP+ printer, go to 123.hp.com to download the printer software, and then follow the prompts to set up your printer and sign in to your HP account. You cannot manually add an HP+ printer to your account using a printer code.
  • If your printer is not listed, continue with these steps.
Step 1: Get the printer code
Connect your printer to the web, and then get the printer code.
Step 2: Find the printer code on the info page
Find the printer code on the info page you printed in the previous step.
  • If the printer code is one long code without any spaces, it is valid for 48 hours after printing the info page. If the code expires, you must print the info page again to get a new code.
  • If the printer code is four groups of numbers and letters with spaces in-between, the code does not expire. If you print another info page, you get a new code. Printer codes printed previously are no longer valid.
  • If the info page does not list a printer code, the printer might already have been added to an HP Smart account. You can remove the printer from that account, or turn Web Services off then on again on the printer. A new info page prints with a new printer code.
Step 3: Use the printer code to add your printer
Sign into your HP Smart account or create a new one, and then add your printer using the printer code.
  1. On your computer or mobile device, go to HP Smart.
  2. If you have an account, click Sign In. If you do not have an account, follow these steps to create one:
    1. Click Create Account.
    2. Fill in the fields:
      • First and last name
      • Email address (this will be your username)
      • Country prefix and phone number
      • Password
      • Country
    3. Click Create Account.
    4. A verification code is sent to your phone number. If you choose, you can have it sent to your email address. Enter the code and click Verify. The message Your account has been verified appears.
  3. On the HP Smart homepage, type the printer code, and then click Add.
    If your printer does not display, click Add a Printer, type the printer code, and then click Add.
    Type the printer code, and then click Add
  4. Type the printer code displayed on the info page, and then click Add.
  5. Under ePrint Settings, click the printer's email address.
    Type a new address, and then click Submit
  6. Type a new printer email address in the text box, and then click Submit.
    • If the address you typed is available: The address updates immediately.
    • If the address you typed is not available: Try a different address, and then click Submit.
    Type a new email address, and then click Submit
Step 4: Complete printer setup
If you were unable to complete printer setup, complete printer setup now using your printer software.
  • HP Smart: Open HP Smart and follow the on-screen instructions to complete the setup process.
  • HP EasyStart: Go to 123.hp.com and download your printer software to complete printer setup.
Step 5: Set up web-connected printing services
After you add your printer on HP Smart, you have access to web-connected services, such as HP Instant Ink and HP ePrint.
Frequently Asked Questions (FAQs)
Review the following list of frequently asked questions.
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
Ország/térség: Flag Magyarország
Műveletek
Betöltés...
