Műveletek
Betöltés...
HP ügyféltámogatás – tudásbázis
Műveletek
Betöltés...
Műveletek
Betöltés...
  • Visszajelzés
Műveletek
Betöltés...
HP Photosmart Plus e-All-in-One (B210a, B210b, B210c, and B210e) Printers - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Select the language/region
  • Load plain paper
  • Install the cartridges
  • Align the printer
Setting up a new All-in-One
Follow these steps to set up the product hardware and install the software.
  1. Remove all tape from the front and back of the product and from the control panel display.
    Ábra : Remove packing tape
    Illustration of removing packing tape
  2. Open the product and remove all the packaging materials from inside the product.
    Ábra : Remove packing materials
    Illustration of removing packing materials
Step two: Connect the power cord and adapter
  1. Connect the power cord to the back of the product.
    Ábra : Connect the power cord to the product
  2. Connect the power cord to the power supply.
    Ábra : Connect the power cord to the power supply
  3. Connect the power cord to the electrical outlet.
    Ábra : Connect the power cord to the electrical outlet
Step three: Turn on power
Press the Power button () to turn the product on.
Ábra : Press the Power button
Graphic: Press the Power button
Step four: Select the language/region
After turning the product on, the product displays a list of possible language settings. Use the following steps to set the default language and country/region for your product.
  1. On the product control panel, touch the correct language. Touch the Down Arrow () to scroll through the languages, if necessary.
  2. When prompted, touch Yes or No to confirm or reject the language selection.
  3. On the product control panel, touch the correct country/region. Touch the Down Arrow () to scroll through the country/region options, if necessary.
  4. When prompted, touch Yes or No to confirm or reject the country/region selection.
Step five: Load plain paper
  1. Raise and hold the output tray in the open position.
  2. Slide the paper width guide to its outermost position.
    Ábra : Slide the paper guide outward
    Graphic: Move the paper width guide outward
  3. Insert the paper stack into the input tray with the short edge forward and print side down.
    Ábra : Load plain paper
    Graphic: Load plain paper
  4. Slide the paper width guide inward until it rests against the stack of paper.
    Ábra : Slide the paper width guide inward
    Graphic: Slide the paper width guide to rest against the paper stack
  5. Lower the output tray, and then pull the tray extender towards you, as far as it will go. Flip the paper catch at the end of the tray extender.
    Ábra : Lower the output tray
    Graphic: Lower the output tray
Step six: Install the cartridges
  1. Press the Power button () to turn on the product, if it is not already turned on. Wait until the product is idle and silent before continuing.
  2. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing.
    Ábra : Open the cartridge access door
    Graphic: Open the cartridge access door
  3. On the new cartridge, pull the orange pull-tab straight back to remove the plastic wrap.
    Ábra : Remove the plastic wrap
    Graphic: Unwrap the new cartridge
  4. Twist the orange cap counter clockwise to snap it off.
    Ábra : Remove the orange cap
    Graphic: Twist the orange cap to remove it
  5. With the cartridge contacts facing the printhead, slide the cartridge into the empty slot. Press down on the cartridge until it clicks firmly into place.
    Ábra : Install the cartridge
    Graphic: Install the new cartridge
  6. Repeat these steps to install the other cartridges.
    Ábra : All cartridges installed
    All catridges installed
  7. Close the cartridge door. The carriage returns to the right side of the product.
    Ábra : Close the cartridge access door
    Graphic: Close the cartridge access door
Step seven: Align the product
After installing the cartridges, touch OK on the product control panel. The product automatically prints an alignment page to align the product.
Ábra : Example alignment page
Graphic: Example alignment page
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
Ország/térség: Flag Magyarország
Műveletek
Betöltés...
