Műveletek
Betöltés...
HP ügyféltámogatás – tudásbázis
Műveletek
Betöltés...
Műveletek
Betöltés...
  • Visszajelzés
Műveletek
Betöltés...
HP LaserJet Pro Printers - Setting Up Printer Hardware
This document is for the LaserJet Pro P1102, P1102s, P1102w, P1106, P1108, P1109, and P1109w printers.
This document includes the following steps to set up the printer:
  • Remove packing tape
  • Prepare the print cartridge
  • Load plain paper
  • Turn on power
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Remove the printer from the box, and then check the contents of the box.
Step 2: Remove packing tape
Remove all packing tape from the printer.
Step 3: Prepare the print cartridge
  1. Open the print cartridge door.
    Ábra : Open the print cartridge door
    Illustration: Open the print cartridge door.
  2. Remove the print cartridge packaging.
    Ábra : Remove the print cartridge packaging
    Illustration: Remove the print cartridge packaging.
  3. Remove the print cartridge from the printer.
    Illustration: Remove the print cartridge.
      vigyázat:
    To prevent damage to the print cartridge, hold the print cartridge at each end.
  4. Remove the packaging from inside the printer.
    Ábra : Remove the packaging from inside the printer.
    Illustration: Remove the packaging from inside the printer.
  5. Remove the orange clip from the end of the print cartridge.
    Ábra : Remove the orange clip from the print cartridge
    Illustration: Remove the orange clip from the print cartridge.
  6. Gently rock the print cartridge back and forth to distribute the toner evenly.
    Ábra : Rock the print cartridge
    Illustration: Rock the print cartridge.
  7. Bend the tab on the left side of the print cartridge until the tab breaks loose, and then pull the tab to remove all the sealing tape from the print cartridge.
    Ábra : Remove the sealing tape
    Illustration: Remove the sealing tape.
      vigyázat:
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  8. Insert the print cartridge, and then close the print cartridge door.
    Ábra : Insert the print cartridge and close the door
    Illustration: Insert the print cartridge and close the door.
Step 4: Load plain paper
To load plain paper in the main input tray, follow these steps.
  1. Slide the paper length and width guides to their outermost positions.
    Ábra : Slide out paper guides
    Illustration: Slide out paper guides.
  2. Load plain paper in the main input tray with the top forward and the print side up.
    Ábra : Load paper
    Illustration: Load paper into the main input tray.
  3. Slide the paper guides inward so that they rest against the stack of paper.
    megjegyzés:
    To prevent jams and skewing, always adjust the side and front paper guides.
    Ábra : Adjust the paper guides
    Illustration: Adjust the paper guides
Step 5: Turn on power
  1. Connect the power cord to the back of the printer.
    Ábra : Connect the power cord
    Illustration: Connect the power cord to back of printer
  2. Plug the power cord into an electrical outlet.
  3. Press the Power button to turn on the printer.
    Ábra : Turn on the power
    Illustration: Turn on the power.
    megjegyzés:
    A blank page might print when you turn on the printer for the first time.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
Ország/térség: Flag Magyarország
Műveletek
Betöltés...
