Műveletek
Betöltés...
HP ügyféltámogatás – tudásbázis
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
HP Laser and LaserJet Printers - Printer Does Not Turn On
This document is for HP Laser and LaserJet printers.
The printer does not turn on or respond when you press the Power button. All the lights are off, and there is no noise or movement from the printer.
Step 1: Reset the power module and test the wall outlet
Unplug the printer to reset the power module, plug another appliance into the wall outlet to test the power, and then reconnect the printer.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. While the printer is unplugged, plug another appliance into the wall outlet, and then turn it on to make sure the outlet works.
    • If the wall outlet does not work, plug the printer into an outlet that does work. Do not use a power strip or surge protector.
    • If the wall outlet works, continue with these steps.
  4. After the printer has been disconnected for at least 60 seconds, reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into the wall outlet. Do not use a power strip or surge protector.
  6. Turn the printer on.
If the printer still does not turn on, continue to the next step.
Step 2: Test the printer Power button or switch
Plug the printer into a working wall outlet, and then test the printer Power button or switch.
  1. Make sure the power cord is connected to the rear of the printer and is plugged directly into a wall outlet.
  2. Depending on your printer model, use the appropriate steps to start a Power On/Off cycle:
    • Printers with a Power button: Press and release the Power button to start a Power On/Off cycle. Do not hold the button down.
      megjegyzés:
      If you press and hold the Power button too long, the printer might turn on and then off without restarting. If this happens, press and quickly release the Power button again.
    • Printers with a Power switch: Press the Power switch to the Off position, and then press it to the On position to reset it and start a Power On/Off cycle.
  3. If the printer does not turn on, wait 10 seconds, and then press the Power button or reset the Power switch again.
If the power indicator remains off, continue to the next step.
Step 3: Test the power with another compatible power cord
HP printers use standard power cords built for computers and electronics. Find a power cord with the same connectors as your printer power cord, and then use the cord to repeat the steps to Reset the power module and test the wall outlet and Test the printer Power button or switch. If you need to obtain a compatible power cord or you need to replace the power cord, go to the HP Parts Store.
  • If the printer turns on with a different power cord, the original power cord caused the issue. Replace the power cord.
  • If the printer does not turn on with a different power cord, continue to the next step.
Step 4: Test the power without the USB cable
If the printer is connected to a PC with a USB cable, disconnect the USB cable, and then turn on the printer. If the printer is not connected with a USB cable, skip to the next step.
  • If the printer turns on with the USB cable disconnected, replace the USB cable. To obtain a replacement USB cable, go to the HP Parts Store.
  • If the printer does not turn on with the USB cable disconnected, continue to the next step.
Step 5: Service or replace the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
Műveletek
Betöltés...
Műveletek
Betöltés...
Műveletek
Betöltés...
Ország/térség: Flag Magyarország
Műveletek
Betöltés...
