- ${title}
Betöltés...
HP ügyféltámogatás – tudásbázis
- ${title}
Betöltés...
- ${title}
Betöltés...
- ${title}
Betöltés...
HP Photosmart C3100 All-in-One Printer Series- Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Connect the power cord and adapter
Turn on power
Load plain paper
Install the cartridges
Follow these steps in order.
Remove all tape and packing material from around the product.
Lower the paper tray and remove all tape and packing material.Ábra : Lower the paper tray
Lower the cartridge door and remove all tape and packing material.Ábra : Lower the cartridge door
Step three: Connect the power cord and adapter
Connect the power cord to the product and the power adapter.Ábra : Connect the power cord and adapter
Connect the power cord to the electrical outlet.
Step four: Turn on power
Press the Power button (
Ábra : Press the Power button -
Wait 30 seconds for the product to start up.
Step five: Load plain paper
Pull out the tray extender.Ábra : Pull out the tray extender
Load plain, unused, white paper.Ábra : Load plain, unused, white paper
Step six: Install the cartridges
Open the cartridge door. Make sure that the carriage moves to the right. If it does not move to the right, turn the product off and then turn it on again.Ábra : Open the cartridge door
Remove the tape from both cartridges.Ábra : Remove the tape
vigyázat:
Do not touch the copper-colored contacts or re-tape the print cartridges.Ábra : Copper-colored contacts -
Hold the cartridges with the HP logo on top.
Insert the tri-color cartridge in the left slot and the black cartridge in the right slot.Ábra : Carriage slotsÁbra : Insert the tri-color cartridge in the left slot
Push the cartridges in firmly until they snap into place.Ábra : Push the cartridge in firmlyÁbra : Tri-color cartridge and black cartridge correctly installed
Close the cartridge door.Ábra : Close the cartridge door
megjegyzés:
Make sure that unused, plain, white paper is loaded in the paper tray, then wait a few minutes while the cartridge alignment page prints. Alignment is complete after the page prints.
További támogatási lehetőségek
- ${title}
Betöltés...
- ${title}
Betöltés...
- ${title}
Betöltés...
Ország/térség:
Magyarország
- ${title}
Betöltés...
hp-hero-support-search
- ${title}
Betöltés...
