- ${title}
Betöltés...
HP ügyféltámogatás – tudásbázis
- ${title}
Betöltés...
- ${title}
Betöltés...
- ${title}
Betöltés...
HP PSC 1300 All-in-One Printer Series - Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Attach the control panel overlay
Connect the power cord and adapter
Turn on power
Load plain paper
Install the cartridges
Align the cartridges
Follow these steps in order.
Remove all plastic, tape, and packaging material.
Remove shipping material and components from inside the product.Ábra : Remove packing material and components
Step three: Attach the control panel overlay
Remove the adhesive backing from the front panel cover.
Raise the lid of the product.
Place the front panel cover into the recess and stick it into place.
vigyázat:The product will not work until the front panel cover is attached.
Step four: Connect the power cord and adapter
Connect the power cord and adapter.
Ábra : Connect power cords
Step five: Turn on power
Press the On/Resume button next to the On light (
Ábra : Press the On/Resume button -
Wait 30 seconds for the product to start up.
Step six: Load plain paper
Lower the input tray and slide the paper guide completely to the left.
Insert plain white letter or A4 paper and adjust the paper guide as needed. Be careful not to force the paper too far into the tray.Ábra : Load plain paper
Step seven: Install the cartridges
With the product still turned on, open the access door. Make sure the carriage movesto the center. If it does not move to the center, turn the product off, thenturn it back on again.Ábra : Carriage for the cartridges
Remove the tape from both cartridges.Ábra : Remove the tape
vigyázat:
Do not touch the copper-colored contacts or re-tape thecartridges.Ábra : Copper-colored contacts -
Hold the cartridges with the large HP label and the raised markings on top.
Insert the blackcartridge in the right cartridge slot, and the tri-color cartridge in the left cartridge slot.
Make sure you push the cartridges in firmly until they snap intoplace.
Close the access door.
Step eight: Align the cartridges
After closing the access door, wait a few minutes while the cartridge alignment page prints.
Place the alignment page face down on the left front corner of the glass and close the lid.Ábra : Load alignment page
Press the Scan button .Ábra : Press the scan button
After the On light stops blinking, alignment is complete. Discard or recycle the alignment page.
További támogatási lehetőségek
- ${title}
Betöltés...
- ${title}
Betöltés...
- ${title}
Betöltés...
Ország/térség:
Magyarország
- ${title}
Betöltés...
hp-hero-support-search
- ${title}
Betöltés...
