Connect the network cable to the product and to the network.Figure : Network connection
Wait for 60 seconds before continuing. During this time, the network recognizes the product and assigns an IP address or host name for the product.
At the product control panel, press the Home button
Press the down arrow
to highlight the Administration menu, and then press the OK button.
to highlight the Reports menu, and then press the OK button.
to highlight the Configuration/Status Pages menu, and then press the OK button.
to highlight the Configuration Page menu, and then press the OK button.
Find the IP address on the Embedded Jetdirect page.Figure : IP address location
IPv4: If the IP address is 0.0.0.0, or 192.0.0.192, or 169.254.x.x, you must manually configure the IP address. See Manually configure IPv4 TCP/IP parameters from the control panelManually configure IPv4 TCP/IP parameters from the control panel. Otherwise, the network configuration was successful.IPv6: If the IP address begins with "fe80:", the product should be able to print. If not, you must manually configure the IP address. See Manually configure IPv6 TCP/IP parameters from the control panelManually configure IPv6 TCP/IP parameters from the control panel.
- ${title}
- ${title}
- ${title}
- ${title}
HP Color LaserJet Enterprise CP5520 Printer Series - Install software for Mac computers on a wired network
Configure the IP address
Install the Mac software
Mac
Quit all programs on the computer.
Install the software from the CD.
Click the product icon, and follow the onscreen instructions.
Click the Close button when the installation is complete.
At the computer, open the Apple menu
, click the System Preferences menu, and then click the Print & Fax icon.
Click the plus symbol (+).By default, Mac OS X uses the Bonjour method to find the driver and add the product to the printer pop-up menu. This method is best in most situations. If Mac OS X cannot find the HP printer driver, an error message displays. Reinstall the software.If you are connecting the product to a large network, you might need to use IP printing to connect rather than Bonjour. Follow these steps:
Click the IP Printer button.
From the Protocol drop-down list, select the HP Jetdirect-Socket option. Enter the IP address or host name for the product. From the Print Using drop-down list, select the product model if one is not already selected.
To configure the product to recognize the installed accessories, complete these steps:Mac OS X 10.4
From the Apple menu
, click the System Preferences menu and then click the Print & Fax icon.
Click the Printer Setup button.
Click the Installable Options menu.
Mac OS X 10.5 and 10.6-
From the Apple menu
Select the product in the left side of the window.
Click the Options & Supplies button.
Click the Driver tab.
Configure the installed options.
For Mac OS X 10.5 and 10.6, the installation procedure should automatically configure the installed options. -
Print a page from any program to make sure that the software is correctly installed.
note:If the installation failed, reinstall the software.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Croatia
- ${title}
hp-hero-support-search
- ${title}
