動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    了解如何升級到 Windows 11
    Windows 11 升級指南
  • 反饋
動作
正在載入...
SUPPORT COMMUNICATION- SECURITY BULLETIN
Document ID: c06990695
Version: 3
HPSBPI03709 rev. 3 - Certain HP and Samsung-branded Print Products - IPv6 Network Stack Vulnerability
Notice: The information in this security bulletin should be acted upon as soon as possible.
Release date : 27-Dec-2020
Last updated : 16-Feb-2022
Potential Security Impact:
Denial of Service
Source: HP, HP Product Security Response Team (PSRT)
VULNERABILITY SUMMARY
HP has identified a potential security vulnerability with the IPv6 network stack of certain HP and Samsung branded printers that could result in a denial of service.
Reference Number
CVE-2020-27336, CVE-2020-27337, CVE-2020-27338; PSR-2020-0245
SUPPORTED SOFTWARE VERSIONS*: ONLY impacted versions are listed.
Please refer to the RESOLUTION section below for a list of potentially impacted products.
BACKGROUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2020-27337
CVSS:3.0/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L
5.3
CVE-2020-27338
5.3
CVE-2020-27336
5.3
RESOLUTION
HP is actively investigating the referenced potential security vulnerability. Subscribe to HP Security Bulletin alerts as described below for further updates on the issue. The current recommendation to help mitigate potential exploitation of the vulnerability is to update firmware or disable IPv6 on the printer.
To disable IPv6, access the Embedded Web Server (EWS) on the printer, and then select Enable IPv4 only as illustrated below.
Enabling IPv4 on the Embedded Web Server (EWS)
For more information on accessing the EWS, refer to Use the HP printer Embedded Web Server (EWS).
Potentially Impacted Products
HP Laser, HP LaserJet Pro, and HP Neverstop Laser
Product Name
Model Number
Resolution
HP Color LaserJet Pro M154
T6B46A, T6B47A, T6B50A, T6B49A, T6B48A, T6B51A, T6B54A, T6B55A, T6B53A, T6B52A
Update firmware to 20211109 or higher
HP Color LaserJet Pro M155
7KW48A, 7KW49A, 7KW50A, 7KW51A
Update firmware to 20211122 or higher
HP Color LaserJet Pro M253, M254
T6B56A, T6B58A, T6B57A, T6B62A, T6B63A, T6B61A, T6B65A, T6B60A, T6B64A, T6B59A
HP Color LaserJet Pro M255
7KW65A, 7KW64A, 7KW63A, 7KW68A, 7KW67A, 7KW66A
HP Color LaserJet Pro M452
CF389A, CF389V, CF394A, CF394V, CF388A, CF388V
Update firmware to 20211118 or higher
HP Color LaserJet Pro MFP M176, M177
CF547A, CZ165A
Follow mitigation above
HP Color LaserJet Pro MFP M180, M181
T6B73A, T6B70A, T6B74A, T6B75A, T6B72A, T6B71A
HP Color LaserJet Pro MFP M182, M183
7KW54A, 7KW55A, 7KW56A, 7KW57A, 7KW59A, 7KW58A
HP Color LaserJet Pro MFP M277, M274
B3Q10A, B3Q11A, B3Q17A, M6D61A
Update firmware to 20220111 or higher
HP Color LaserJet Pro MFP M280, M281
T6B85A, T6B84A, T6B80A, T6B83A, T6B86A, T6B81A, T6B82A
HP Color LaserJet Pro MFP M282, M283
7KW72A, 7KW73A, 7KW74A, 7KW75A, 7KW76A, 7KW77A, 7KW78A, 7KW79A
HP Color LaserJet Pro MFP M377, M477
M5H23A, CF378A, CF379A, CF377A
HP LaserJet Multifunction Printer series M1130, M1200
B4K88A, CE841A, CE842A, CE843A, CE844A, CE845A, CE846A, CE847A, CE848A, CE849A, CE850A
HP LaserJet Pro 400 M401
CF270A, CF274A, CF278A, CF285A, CF399A, CZ195A
Update firmware to 20210202 or higher
HP LaserJet Pro 400 MFP M425
CF286A, CF288A
HP LaserJet Pro 500 color MFP M570
CZ271A, CZ272A
Update firmware to 20220112 or higher
HP LaserJet Pro CP1025
CF346A, CE918A
HP LaserJet Pro M102, M104, M106
G3Q34A, G3Q35A, G3Q36A, G3Q37A, G3Q39A
Update firmware to 20211215 or higher
HP LaserJet Pro M12w
T0L46A
HP LaserJet Pro M15, M16, M17
W2G50A, W2G51A, W2G52A, W2G53A, Y5S43A
Update firmware to 20201013 or higher
HP LaserJet Pro M201, M202
C6N20A, C6N21A, CF455A, CF456A
HP LaserJet Pro M203, M206, M118
4PA39A, G3Q46A, G3Q47A, G3Q48A, G3Q50A
HP LaserJet Pro M225, M226
C6N22A, C6N23A, CF484A, CF485A, CF486A
HP LaserJet Pro M402, M403
C5F92A, C5F93A, C5F94A, C5F95A, C5F96A, C5J91A, G3V21A, F6J41A, F6J42A, F6J43A, F6J44A
HP LaserJet Pro M435
A3E42A
HP LaserJet Pro M501
J8H60A, J8H61A
Update firmware to 20210810 or higher
HP LaserJet Pro M521
A8P79A, A8P80A
HP LaserJet Pro M701, M706
B6S00A, B6S01A, B6S02A
HP LaserJet Pro MFP M125, M126, M127, M128
CZ172A, CZ173A, CZ174A, CZ175A, CZ181A, CZ182A, CZ183A, CZ184A, CZ185A, CZ186A
HP LaserJet Pro MFP M130, M132, M134
G3Q57A, G3Q58A, G3Q59A, G3Q60A, G3Q61A, G3Q62A, G3Q63A, G3Q64A, G3Q65A, G3Q66A, G3Q67A, G3Q68A
HP LaserJet Pro MFP M26
T0L49A, T0L50A
HP LaserJet Pro MFP M29, M31
W2G54A, W2G55A, W2G56A, W2G57A, Y5S53A, Y5S50A, Y5S54A, Y5S55A
HP LaserJet Pro MFP M426, M427
C5F97A, C5F98A, C5F99A, F6W13A, F6W14A, F6W15A, F6W16A, F6W17A, F6W18A, F6W19A
HP LaserJet Pro P1102, P1106, P1108
CE651A, CE653A, CE655A, CE657A, CE658A
HP LaserJet Ultra MFP M230 HP LaserJet Pro MFP M227, M148, M149
4PA41A, 4PA42A, 4PA44A, G3Q74A, G3Q75A, G3Q76A, G3Q77A, G3Q78A, G3Q79A
HP Neverstop Laser 1200a, 1005c
4QD21A, 4RY26A, 4YE52A, 4YE53A, 5NL12A
Samsung proXpress and Samsung MultiXpress
Product Name
Model Number
Resolution
Samsung MultiXpress SL-K302NR/GOV
Samsung MultiXpress SL-K3300NR
SS026B, SS027A, SS027B, SS027C, SS027D, SS027E, SS027F, SS027G, SS027H, SS027J, SS027K, SS027L, SS0028E
Samsung MultiXpress SL-X3220NR
Samsung MultiXpress SL-X3280NR
SS043A, SS043B, SS043C, SS043D, SS043E, SS043F, SS043G, SS043H SS043J, SS043K, SS043L, SS043M, SS044G
Samsung Printer proXpress SL-C3510ND
Samsung Printer proXpress SL-C3510ND/SLI
Samsung Printer proXpress SL-C4010N
Samsung Printer proXpress SL-C4010ND
Samsung Printer proXpress SL-C4010ND/GOV
SS214A, SS214B, SS215A, SS216A, SS216B, SS216C, SS216D, SS216E, SS216F, SS216G, SS216H, SS216J, SS216K, SS216L, SS216M, SS216N, SS216P, SS216Q, SS216S, SS216T, SS216U, SS216V, SS216Z
Samsung ProXpress SL-C3010 Color Laser Printer series
SS209A, SS210A, SS210B, SS201C, SS210D, SS210E, SS210F, SS210G, SS210H, SS210J, SS210K, SS210L, SS210M, SS210P
Samsung ProXpress SL-C3060FR Color Laser Multifunction Printer
SS211A, S221B, SS211C, SS211D, SS211E, SS211F, SS211G, SS211H, SS211J, SS211K, SS211L, SS211M, SS211N, SS211P, SS211Q
Samsung ProXpress SL-C3060ND Color Laser Multifunction Printer
SS213A, SS213B, SS213C, SS213D, SS213E, SS213F, SS213G, SS213H
Samsung proXpress SL-M3310ND/GOV
Samsung proXpress SL-M3820DW
Samsung proXpress SL-M3320ND
Samsung proXpress SL-M3820ND
Samsung proXpress SL-M3820ND/KRM
Samsung proXpress SL-M4020ND
Samsung proXpress SL-M4020ND/GOV
Samsung proXpress SL-M4021ND
Samsung proXpress SL-M4021ND/GOV
SS364B, SS365H, SS371A, SS371B, SS371C, SS371D, SS372C, SS375B, SS373A, SS373B, SS373C, SS373D, SS373E, SS373F, SS373G, SS373H, SS373J, SS373K, SS373L, SS373M, SS373N, SS373P, SS373Q, SS373S, SS373T, SS373U, SS373V, SS373W, SS373Z, SS383K, SS383L, SS383X, SS383Y, SS383C
Samsung proXpress SL-M3370FD
Samsung proXpress SL-M3870FW/KRM
Samsung proXpress SL-M3375FD
Samsung proXpress SL-M4070FR/GOV
SS368A, SS368B, SS368C, SS368D, SS368E, SS368F, SSE68G, SS368H, SS368J, SS369A, SS369B, SS369C, SS369D, SS369E, SS378E, SS389J, SS390C
Samsung proXpress SL-M4530ND
SS397A, SS397B, SS397C, SS397D, SS397E, SS397F, SS397G, SS397H, SS397J, SS397K, SS397L, SS397M, SS397M, SS397N, SS397P, SS397Q, SS398A, SS398B, SS398C, SS398D, SS398E, SS398F, SS398G
Samsung Xpress SL-M2835 Laser Printer
SS346A, SS346B, SS346C, SS346D, SS346E, SS346F, SS346G, SS346F, SS346G, SS346H, SS346J, SS346K, SS346L, SS346M
Samsung Xpress SL-M2885 Laser Multifunction Printer
SS359A, SS359B, SS359C, SS359D, SS359E, SS359F, SS359G, SS359H, SS359J, SS359K, SS359L, SS359M, SS359N, SS359P, SS359Q, SS359Z
HP DeskJet, HP OfficeJet, HP OfficeJet Pro, HP Ink Tank, and HP Smart Tank
Product Name
Model Number
Resolution
HP Deskjet 2540 All-in-One/ HP Deskjet 2545 All-in-One
K9B57B, K9B59A, K8T38A, K9B56A, D3A81A, A9U22A, A9U22B, A9U19A, K2W35A, A9U27A, A9U28B, D3A80A, J7V18B, D3A78B, D3A79A, D3A82A, J7V17B, J7V19B, K9B54A, E1E94B, K9B55A
HP DeskJet 2600 All-in-One Printer
V1N01B, V1N01C, Y5H80A, Y5H68A, Y5H68D, 4UJ28B, V1N07A, Y5H67A, Y5H67D, Y5H69A, Y5H69D, V1N08A, Y5H60A, Y5H61A, Y5H62A, Y5H72D, V1N03B, V1N03C, V1N05B, V1N05C, V1N06B, V1N07B, Y5H63A, Y5H64A, Y5H65A, V1N05A, V1N01A, V1N03A, V1N04A, 5SF02A, 5SF03A, 5SF04A, Y5H58A, Y5H66A
HP DeskJet 2700 All-in-One Printer series
HP DeskJet Ink Advantage 2700 All-in-One series
HP DeskJet Plus 4100 All-in-One series
HP DeskJet Plus Ink Advantage 4100 All-in-One series
HP DeskJet 4100e All-in-One series
3XV13A, 3XV14B, 3XV14C, 3XV15A, 3XV15D, 3XV17A, 3XV18B, 3XV18C, 3XV19A, 3XV19D, 4WS03B, 4WS04A, 4WS04B, 5AR83A, 5AR83B, 5AR84A, 5AR85A, 7FR20A, 7FR21A, 7FR26B, 7FR27B, 7FR28B, 7FR29B, 7FR48D, 7FR50B, 7FR52A, 7FR53A, 7FR53B, 7FR54B, 7FR55B, 7FR56D, 7FR57A, 7FR57D, 7FR58A, 7FR59D, 7FR60D, 7FR61A, 7FS74A, 7FS74D, 7FS75D, 7FS76A, 7FS77B, 7FS79A, 7FS79B, 7FS81B, 7FS83D, 7FS86A, 7FS87A, 7FS87D, 7FS88A, 7FS88D, 7HZ98B, 7HZ99B, 7MR23A, 7MR24A, 8QB70A, 8RK11A, 26Q91B, 26Q90B, 26Q94A, 26Q95A, 26Q92B, 26Q96A, 26Q97A, 26Q93B, 2A9T7A, 26Q91A, 26Q90A, 26Q93A
HP Deskjet 3520 e-All-in-One
CX052A, CX052B, CX052C, CX053C, CX056A, CX056AR, F6H93A, CX058A, E3P97A, CX055B, CX057A, CX054B, CX059A
HP DeskJet 3630 All-in-One Printer
F5S43A, F5S57A, K4T99B, K4T99C, K4T94A, F5S47A, F5S48A, F5S49B, K4T95A, K4U03B, F5S50B, K4T93A, F5S56B, K4T96A, K4U00B, V3F21A, V3F22A, K4T97A, K4U01B, K4U02B, F5S43B, F5S43C
HP DeskJet 3790 series (HP AMP 100, 130, 100, 105)
T8X39A, T8X40A, T8X42A, T8X39D, T8X44A, 1SH08A, T8X40D, T8X39B, T8X39C, T8X40B
HP Deskjet 5520 e-All-in-One
C7G19A, CX042A, CX042B, CX045C, CX046C, K8G35A, CX042AR, CX049C, CX044A, CX048B, CX047B, CX043A, CX043B
HP DeskJet GT 5820 All-in-One Printer
2ND31A, M2Q28A, P0R21A, X3B09A, 1WW50A, 2ND32A, P0R22A
HP DeskJet Ink Advantage 2600 All-in-One Printer
V1N02A, V1N02B, Y5Z00A, Y5Z03B, Y5Z04B, Y5Z02B, 7FQ79B, 7FQ80B, 7FQ81B
HP Deskjet Ink Advantage 3540 e-All-in-One Printer
E6G69A, A9T81A, A9T81B, A9T81C, F9A24A, L5T77A, A9T82A, A9T84C, A9T83B
HP DeskJet Ink Advantage 3630 All-in-One Printer
F5S44A, F5S44B, F5S44C, K4U06A, K4U07A, K4U08A, F5S45A, F5S53C, K4U05B, F5S46B
HP DeskJet Ink Advantage 3700 All-in-One Printer series
HP DeskJet 3700 All-in-One Printer series
1DT61A, 1DT62A, 3YZ74A, 3YZ75A, 4SC29A, 4SC30A, 7FM64B, 7FM65B, 7FM66B, J9V86A, J9V86B, J9V87A, J9V87B, J9V87C, J9V88A, J9V89B, J9V90A, J9V91A, J9V92A, J9V93B, J9V94B, J9V95B, J9V96B, J9V97B, T8W35A, T8W36A, T8W37A, T8W38A, T8W39B, T8W40B, T8W41B, T8W42C, T8W46C, T8W47C, T8W48C, T8W49C, T8W50C, T8W51A, T8W52A, T8W54A, T8W56A, T8W57A, T8W58A, T8W59A, T8W83A, T8W92A, T8W93A, T8W94A, T8W95A, T8W96A, T8X00B, T8X01B, T8X04B, T8X05B, T8X06B, T8X07B, T8X10B, T8X12B, T8X19B, T8X23B, T8X27B
HP Deskjet Ink Advantage 3830 e-All-in-One Printer
F5R96A, F5R96B, F5R96C, F5R97A, F5R98B
HP Deskjet Ink Advantage 4530 All-in-One Printer
E6G68A, F0V64A, F0V64B, F0V64C, F0V65A, F0V66B
HP DeskJet Ink Advantage 4670 All-in-One Printer
F1H97A, 1H97B, F1H97C, F1H98A, F1H99B
HP DeskJet Ink Advantage 5570 All-in-One Printer
G0V48B, G0V48C
HP DeskJet Ink Advantage Ultra 4720 All-in-One Printer
F5S65A, F5S66A, L8L91A
HP ENVY 4500 e-All-in-One Printer
N4E46A, A9T80A, A9T80B, D3P93A, F2K48A, K2M74A, C8D05A, A9T85A, A9T87B, E6G71B, A9T88B, A9T89A, C8D04A, A9T86A, D3P95A, E6G70B, E6G72B, D3P94A, D3P94B
HP ENVY 4510 All-in-One Printer
K9H48A, K9H50A, K9H49A, K9H51A, K9H52A, K9H53A
HP Envy 4520 All-in-One Printer
E6G67A, E6G67B, F0V63A, F0V63B, F0V69A, J6U70B, K9T10B, F0V67A, F0V70B, F0V73A, J6U59B, J6U60B, W3U26A, F0V71B, F0V72B, J6U69A, K9T01A, K9T09B, K9T05B, J6U61B, K9T06B, K9T07B, K9T08B
HP ENVY 5530 e-All-in-One Printer
A9J40A, A9J40B, A9J49A, A9J47A, K2M73A, A9J45A, A9J48B, A9J46A, D4J85B, A9J44A, K3Z41A, D4J86B, A9J48A
HP ENVY 5540 All-in-One Printer
F2E72A, G0V47A, G0V52A, G0V53A, J6U66A, K7C85A, K7G89A, G0V51A, K7C86A, K7C87A, K7C88A, K7G90A, N9U88A, G0V54A, K7C89A, K7C93A, G0V50A, K7G88A, J6U67A, K7C90A, J6U64A, K7G87A, K7G86A
HP ENVY 5640 e-All-in-One Printer
B9S56A, B9S58A, B9S59A, B9S61A, B9S64A, F8B13A, K5L42A, B9S63A, B9S62A, B9S65A, F8B05A
HP ENVY 5660 e-All-in-One Printer
F8B04A, F8B04AR, F8B07A, F8B12A, T5R62A, F8B06A, F8B08A
HP Envy 7640 e-All-in-One Printer series
E4W43A, E4W43B, E4W47A, E4W43AR, E4W45A, E4W46A, E4W44A
HP Ink Tank Wireless 410
Z6Z95A, 4YF79A, Z6Z99A, 4DX94A, Z4B53A, 4DX95A, Z4B55A, Z7A01A, Z4B54A, Z6Z97A
HP Neverstop Laser 1000, 1020
4RY22A, 4RY23A, 4YE47A, 4YE48A, 4YE51A, 5HG74A, 5HG80A
HP Officejet 200 Mobile Printer Series
CZ993A, L9B95A
HP Officejet 202 Mobile Printer Series
N4K99C, N4L14C
HP OfficeJet 250 Mobile Series
CZ992A, L9D57A, N4L17A, N4L16C, N4L18C
HP Officejet 3830 e-All-in-One Printer
F5R95A, F5R95B, F5R95C, K7V40A, K7V36A, K7V45B, F5R99A, F5S01B, F5S03B, K7V37A, F5S02B, K7V44B, K7V38A
HP Officejet 4630 e-All-in-One Printer
B4L03A, B4L03B, B4L03C, D4J76A, E6G81A, E6G81B, B4L07A, B4L05A, B4L06B, E6G85B, D4J74A, D4J78B, B4L04A, E6G86B, D4J75A, D4J77B
HP OfficeJet 4650 All-in-One Printer
E6G87A, F1H96A, F1H96B, F1J03A, F1J04A, F9D37A, K9V77A, K9V85B, K9V83B, F1J02A, F1J05B, K9V84B, F1J06B, F1J07B, K9V76A, F1J00A, K9V79A, K9V82B, K9V81B, V6D27B, V6D29B, V6D28B, V6D30B
HP Officejet 5740 e-All-in-One Printer series
B9S76A, B9S78A, B9S79A, B9S83A, B9S81A, B9S84A, F8B11A, F8B10A, B9S82A, B9S85A, B9S80A, F8B09A, T1P36A
HP OfficeJet 6950 All-in-One
P4C78A, P4C85A, T3P03A, P4C86A, P4C81A, P4C82A, P4C84A
HP OfficeJet 6960 All-in-One
HP OfficeJet Pro 6960 All-in-One
T0G25A, T0G26A, J7K33A, T0F30A, T0F32A, T0F38A, T0F31A, J7K37A, J7K38A, J7K35A, J7K39A, T0F28A, T0F36A
HP Officejet 7110 Wide Format ePrinter
CR768A
HP Officejet 7510 Wide Format e-All-in-One
G3J47A, K1Z44A
HP Officejet 7610 Wide Format e-All-in-One
CR769A, G1X85A
HP Officejet Pro 6230 / 6220 ePrinter
E3E03A
HP OfficeJet Pro 6970 All-in-One Printer series
J7K34A, T0F33A, T0F39A, T0F34A, T0F35A, J7K40A, J7K36A, J7K42A, J7K41A, T0F29A, T0F37A, T0F40A
HP Officejet Pro 8630 e-All-in-One
A7F66A
HP OfficeJet Pro 8710 All-in-One Printer series
HP OfficeJet Pro 8720 All-in-One Printer series
D9L18A, D9L19A, J6X76A, J6X77A, J6X78A, J6X79A, J6X80A, J6X81A, J7A28A, J7A29A, J7A31A, K7S34A, K7S35A, K7S36A, K7S37A, K7S38A, M9L65A, M9L66A, M9L67A, M9L70A, M9L74A, M9L75A, M9L76A, M9L80A, T0G46A, T0G47A, T0G48A, T0G49A, T0G54A
HP OfficeJet Pro X451, X551 Printer
CV037A, CN463A
HP Photosmart 6520 e-All-in-One
CX017A, CX017B, CX020C, CX021C, CX018A, CX018B
HP Smart Tank Wireless 450
Z6Z96A, Z4B56A, Z6Z98A
HP DesignJet
Product Name
Model Number
Resolution
HP DesignJet T100 24-in Printer
HP DesignJet T125 24-in Printer
HP DesignJet T130 24-in Printer
HP DesignJet T525 24-in Printer
HP DesignJet T530 24-in Printer
HP DesignJet T525 36-in Printer
HP DesignJet T530 36-in Printer
5ZY56A, 5ZY57A, 5ZY58A, 5ZY59A, 5ZY60A, 5ZY60B, 5ZY61A, 5ZY62A, 5ZY62B
HP DesignJet T120 24-in ePrinter
HP DesignJet T120 24-in Printer
HP DesignJet T120 24-in Printer (2018 edition)
HP DesignJet T520 24-in ePrinter
HP DesignJet T520 24-in Printer
HP DesignJet T520 24-in Printer (2018 edition)
HP DesignJet T520 24-in Printer (2018 edition, legless)
CQ891A, CQ891B, CQ891C, CQ890A, CQ890B, CQ890C, CQ890D, CQ890E
HP DesignJet T520 36-in ePrinter
CQ890A, CQ891A, CQ893A
HP DesignJet T520 36-in Printer
HP DesignJet T520 36-in Printer (2018 edition)
HP DesignJet T520 36-in Printer (2018 edition, legless)
CQ890B, CQ890C, CQ890D, CQ891B, CQ891C, CQ893B, CQ893C, CQ893E CQ893A, CQ893B, CQ893C, CQ893E
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit https://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://www.hp.com/go/alerts.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin. HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action. HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin. To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISION HISTORY : Version 1: 27 December 2020 - Initial release; Version 2: 2 February 2022 - updated product table; Version 3: 16 February 2022 - updated product table
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
