動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    了解如何升級到 Windows 11
    Windows 11 升級指南
  • 反饋
動作
正在載入...
SUPPORT COMMUNICATION- SECURITY BULLETIN
Document ID: c06911998
Version: 3
HPSBPI03688 rev. 3 - Certain HP Printer and MFP products - Cross-Site Scripting (XSS)
Notice: The information in this security bulletin should be acted upon as soon as possible.
Release date : 17-Sep-2020
Last updated : 08-Jul-2022
Potential Security Impact:
Cross-site Scripting (XSS)
Source: HP, HP Product Security Response Team (PSRT)
Reported by: The jQuery Foundation
VULNERABILITY SUMMARY
A potential security vulnerability has been identified for certain HP printers and MFPs. In jQuery versions before 3.5.0, passing HTML from untrusted sources may execute untrusted code.
jQuery is a JavaScript library used to simplify website creation and execution. It is open source software used in many available websites.
Reference Number
CVE-2020-11022, CVE-2020-11023, PSR-2020-0187
SUPPORTED SOFTWARE VERSIONS*: ONLY impacted versions are listed.
Please refer to the RESOLUTION section below for a list of potentially impacted products.
BACKGROUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2020-11022
CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:C/C:L/I:L/A:N
6.1
CVE-2020-11023
6.1
RESOLUTION
HP has provided firmware updates for potentially impacted printers for the products listed in the table below.
To obtain the updated firmware, go to the HP Software site and search for your printer model.
注意:
For firmware marked with *, please contact HP support to obtain the firmware update.
Product Name
Model Numbers
Updated Firmware
HP Color LaserJet Enterprise CM4540 MFP
CC419A, CC420A, CC421A
FS3: 3.9.9 (2309059_000621) or higher
HP Color LaserJet Enterprise CP5525
CE707A, CE708A, CE709A
FS3: 3.9.9 (2309059_000618) or higher
HP Color LaserJet Enterprise M552
B5L23A
FS3: 3.9.9 (2309059_000614) or higher
FS4: 4.11.01 (2411097_060479) or higher
HP Color LaserJet Enterprise M553
HP Color LaserJet Managed M553
B5L24A, B5L25A, B5L26A, BL27A, B5L38A, B5L39A
FS4: 4.11.01 (2411097_060479) or higher*
HP Color LaserJet Enterprise M554, M555
7ZU78A, 7ZU79A, 7ZU81A
HP LaserJet Enterprise 500 color MFP M575
HP LaserJet Enterprise color Flow MFP M575
CD644A, CD645A, CD646A
FS3: 3.9.9 (2309059_000598) or higher
FS4: 4.11.01 (2411097_060489) or higher
HP Color LaserJet Enterprise MFP M577
HP Color LaserJet Enterprise Flow MFP
B5L46A, B5L47A, B5L48A, B5L54A
FS3: 3.9.9 (2309059_000586) or higher
FS4: 4.11.01 (2411097_060474 ) or higher
HP Color LaserJet Managed MFP M577
HP Color LaserJet Managed Flow MFP M577
B5L49A, B5L50A
HP Color LaserJet Enterprise M651
HP Color LaserJet Managed M651
CZ255A, CZ256A, CZ257A, H0DC9A, L8Z07A
FS3: 3.9.9 (2309059_000597) or higher
FS4: 4.11.01 (2411097_060488 ) or higher
HP Color LaserJet Enterprise M652
J7Z98A, J7Z99A
FS4: 4.11.01 (2411097_060484) or higher
HP Color LaserJet Enterprise M653
J8A04A, J8A05A, J8A06A
HP Color LaserJet Enterprise MFP M680
HP Color LaserJet Enterprise Flow MFP M680
CZ248A, CZ249A, CZ250A, CA251A
FS3: 3.9.9 (2309059_000602) or higher
FS4: 4.11.01 (2411097_060475) or higher
HP Color LaserJet Managed MFP M680
HP Color LaserJet Managed Flow MFP M680
L3U47A, L3U48A
HP Color LaserJet Enterprise MFP M681
HP Color LaserJet Enterprise Flow MFP M681
J8A10A, J8A11A, J8A12A, J8A13A
FS4: 4.11.01 (2411097_060480) or higher
HP Color LaserJet Enterprise MFP M682
HP Color LaserJet Enterprise Flow MFP M682
J8A16A, J8A17A
HP Color LaserJet Enterprise M750
D3L08A, D3L09A, D3L10A
FS3: 3.9.9 ( 2309059_000608) or higher
HP Color LaserJet Enterprise M751
HP Color LaserJet Managed E75245
T3U43A, T3U44A, T3U64A
FS4: 4.11.01 (2411097_060467) or higher
HP Color LaserJet Enterprise MFP M776
HP Color LaserJet Enterprise Flow MFP M776
T3U55A, T3U56A
FS4: 4.11.01 (2411097_060500) or higher
HP Color LaserJet Enterprise M855
A2W77A, A2W78A, A2W79A, D7P72A, D7P73A
FS3: 3.9.9 (2309059_000596) or higher
FS4: 4.11.01 (2411097_060471) or higher
HP Color LaserJet Enterprise M856
T3U51A, T3U52A
FS4: 4.11.01 (2411097_060502) or higher
HP Color LaserJet Enterprise Flow MFP M880z
HP Color LaserJet Managed Flow MFP M880zm
D7P70A, A2W75A, A2W76A, D7P70A, D7P71A, L3U51A, L3U52A
FS3: 3.9.9 (2309059_000589) or higher
FS4: 4.11.01 (2411097_060495) or higher
HP Color LaserJet Managed E55040dw
3GX98A
HP Color LaserJet Managed MFP E57540
HP Color LaserJet Managed Flow MFP E57540
3GY25A, 3GY26A
HP Color LaserJet Managed E65050/60
L3U55A, L3U56A, L3U57A
HP Color LaserJet Managed E65150/60
3GY03A, 3GY04A
HP Color LaserJet Managed MFP E67550/60
HP Color LaserJet Managed Flow MFP E67550/60
L3U66A, L3U67A, L3U69A, L3U70A,
HP Color LaserJet Managed MFP E67650/60
3GY31A, 3GY32A
HP Color LaserJet Managed MFP E77422-E77428
5CM75A, 5CM76A, 5CM77A, 5CM78A, 5CM79A, 5RC91A, 5RC92A
FS4: 4.11.01 (2411097_060501) or higher
HP Color LaserJet Managed MFP E77822/25/30
HP Color LaserJet Managed Flow MFP E77822/25/30
X3A77A, X3A80A, X3A83A, Z8Z01A, Z8Z0A, Z8Z05A, X3A78A, X3A81A, X3A84A, Z8Z00A, Z8Z02A, Z8Z04A
FS4: 4.11.01 (2411097_060469) or higher
HP Color LaserJet Managed MFP E78223-E78228
8GS12A, 8GS13A, 8GS14A, 8GS15A, 8GS36A, 8GS37A, 8GS43A, 8GS44A, 8GS50A, 17F27AW, 19GSAW
HP Color LaserJet Managed MFP E78323/30
8GS00A, 8GS01A, 8GS25A, 8GS26A, 8GS27A, 8GS28A, 8GS29A, 8GS30A, 8GR94A, 8GR95A, 8GR96A, 8GR97A, 8GR98A, 8GR99A, 8PE94A, 8PE95A, 8PE96A, 8PE97A, 8PE98A, 9RT91A, 9RT92A
HP Color LaserJet Managed E85055
T3U66A
HP Color LaserJet Managed MFP E87640/50/60
HP Color LaserJet Managed Flow MFP E87640/50/60
X3A86A, X3A87A,X3A89A, X3A90A, X3A92A, X3A93A, Z8Z12A, Z8Z13A, Z8Z14A, Z8Z15A, Z8Z16A, Z8Z17A
FS4: 4.11.01 (2411097_060464) or higher
HP Color LaserJet Managed MFP E87640du-E87660du
5CM63A, 5CM64A, 5CM65A, 5CM66A, 5FM80A, 5FM81A, 5FM82A, 5RC86A, 5RC87A, 5RC88A
HP LaserJet Enterprise M4555 MFP
CE502A, CE503A, CE504A, CE738A
FS3: 3.9.9 ( 2309059_000619) or higher
HP LaserJet Enterprise M506
HP LaserJet Managed M506
F2A68A, F2A69A, F2A70A, F2A71A, F2A66A, F2A67A
FS3: 3.9.9 (2309059_000588) or higher
FS4: 4.11.01 (2411097_060487) or higher*
HP LaserJet Enterprise M507
1PV86A, 1PV87A, 1PV88A, 1PV89A
FS4: 4.11.01 (2411097_060463) or higher
HP LaserJet Enterprise 500 MFP M525f
HP LaserJet Enterprise Flow MFP M525
CF116A, CF117A, CF118A
FS3: 3.9.9 (2309059_000592) or higher
FS4: 4.11.01 (2411097_060476) or higher
HP LaserJet Managed 500 MFP M525
HP LaserJet Managed Flow MFP M525
L3U59A, L3U60A
HP LaserJet Enterprise MFP M527
HP LaserJet Enterprise Flow MFP M527z
F2A76A, F2A77A, F2A78A, F2A81A
FS3: 3.9.9 ( 2309059_000587) or higher
FS4: 4.11.01 ( 2411097_060468) or higher
HP LaserJet Managed MFP M527
HP LaserJet Managed Flow MFP M527z
F2A79A, F2A80A
HP LaserJet Enterprise MFP M528
1PV49A, 1PV64A, 1PV65A, 1PV66A, 1PV67A
FS4: 4.11.01 (2411097_060496) or higher
HP LaserJet Enterprise 500 Color Printer M551
CF081A,CF082A,CF083A
FS3: 3.9.9 (2309059_000590) or higher
HP LaserJet Managed 500 color MFP M575
HP LaserJet Managed color Flow MFP M575
L3U45A, L3U46A
HP LaserJet Enterprise 600 Printer M601
CE989A, CE990A
FS3: 3.9.9 (2309059_000599) or higher
HP LaserJet Enterprise 600 Printer M602
CE991A, CE992A, CE993A
HP LaserJet Enterprise 600 Printer M603
CE994A, CE995A, CE996A
HP LaserJet Enterprise M604
E6B67A, E6B68A
FS3: 3.9.9 (2309059_000616) or higher
FS4: 4.11.01 (2411097_060486) or higher*
HP LaserJet Enterprise M605
HP LaserJet Managed M605
E6B69A, E6B70A, E6B71A
HP LaserJet Enterprise M606
E6B72A, E6B73A
HP LaserJet Enterprise M607
K0Q14A, K0Q15A
FS4: 4.11.01 (2411097_060466) or higher
HP LaserJet Enterprise M608
K0Q17A, K0Q18A, K0Q19A, M0P32A
HP LaserJet Enterprise M609
K0Q20A, K0Q21A, K0Q22A
HP LaserJet Enterprise M610
7PS81A, 7PS82A
HP LaserJet Enterprise M611
7PS83A, 7PS84A, 7PS85A
HP LaserJet Enterprise M612
7PS86A, 7PS87A, 7PS88A
HP LaserJet Managed MFP M630
HP LaserJet Managed Flow MFP M630
L3U61A, L3U62A, P7Z48A
FS3: 3.9.9 (2309059_000593) or higher
FS4: 4.11.01 (2411097_060483) or higher
HP LaserJet Enterprise MFP M630
HP LaserJet Enterprise Flow MFP M630
B3G84A, B3G85A, J7X28A, B3G86A, P7Z47A
HP LaserJet Enterprise MFP M631
HP LaserJet Enterprise Flow MFP M631
J8J63A, J8J64A, J8J65A
FS4: 4.11.01 (2411097_060478) or higher
HP LaserJet Enterprise MFP M632
HP LaserJet Enterprise Flow MFP M632
J8J70A, J8J71A, J8J72A
HP LaserJet Enterprise MFP M633
HP LaserJet Enterprise Flow MFP M633
J8J76A, J8J78A
HP LaserJet Enterprise MFP M634
HP LaserJet Enterprise Flow MFP M634
7PS94A, 7PS95A, 7PS96A
HP LaserJet Enterprise MFP M635
HP LaserJet Enterprise Flow MFP M635
7PS97A, 7PS98A, 7PS99A
HP LaserJet Enterprise MFP M636
HP LaserJet Enterprise Flow MFP M636
7PT00A, 7PT01A
HP LaserJet Enterprise 700 Printer M712
CF235A, CF236A, CF238A
FS3: 3.9.9 (2309059_000605) or higher
HP LaserJet Enterprise MFP M725
HP LaserJet Managed MFP M725
CF066A, CF067A, CF068A, CF069A, L3U63A, L3U64A
FS3: 3.9.9 (2309059_000609) or higher
FS4: 4.11.01 (2411097_060473) or higher
HP LaserJet Enterprise 700 color MFP M775
HP Color LaserJet Managed MFP M775
CF304A, CC522A, CC523A, CC524A, L3U49A, L3U50A
FS3: 3.9.9 ( 2309059_000607) or higher
FS4: 4.11.01 (2411097_060491) or higher
HP LaserJet Enterprise M806
CZ244A, CZ245A
FS3: 3.9.9 (2309059_000606) or higher
FS4: 4.11.01 (2411097_060490 ) or higher
HP LaserJet Enterprise Flow MFP M830
HP LaserJet Managed Flow MFP M830
CF367A, L3U65A
FS3: 3.9.9 (2309059_000617) or higher
FS4: 4.11.01 (2411097_060477) or higher
HP LaserJet Managed E50045
3GN19A
HP LaserJet Managed E50145
1PU51A, 1PU52A
HP LaserJet Managed MFP E52545
HP LaserJet Managed Flow MFP E52545c
3GY19A, 3GY20A
HP LaserJet Managed MFP E52645
1PS54A, 1PS55A
HP LaserJet Managed E60055/65/75
M0P33A, M0P35A, M0P36A, M0P39A, M0P40A
HP LaserJet Managed E60155/65/75
3GY09A, 3GY10A, 3GY12A
HP LaserJet Managed MFP E62555/65
HP LaserJet Managed Flow MFP E62555/65/75
J8J66A, J8J67A, J8J73A, J8J74A, J8J79A, J8J80A
HP LaserJet Managed MFP E62655/65
HP LaserJet Managed Flow MFP E62675
3GY14A, 3GY15A, 3GY16A, 3GY17A, 3GY18A
HP LaserJet Managed MFP E72425/30
5CM68A, 5CM69A, 5CM70A, 5CM71A, 5CM72A, 5RC89A, 5RC90A
FS4: 4.11.01 (2411097_060493) or higher
HP LaserJet Managed MFP E72525/30/35
HP LaserJet Managed Flow MFP E72525/30/35
X3A59A, X3A60A,X3A62A, X3A63A, X3A65A, X3A66A, Z8Z06A, Z8Z07A, Z8Z08A, Z8Z09A, Z8Z010A, Z8Z011A
FS4: 4.11.01 (2411097_060470) or higher
HP LaserJet Managed MFP E82540/50/60
HP LaserJet Managed Flow MFP E82540/50/60
X3A68A, X3A69A, X3A71A, X3A72A, X3A74A, X3A75A, X3A79A, X3A82A, Z8Z18A, Z8Z19, AZ8Z20A, Z8Z22A, Z8Z23A
FS4: 4.11.01 (2411097_060465) or higher
HP LaserJet Managed MFP E82540/50/60du
5CM59A, 5RC83A, 5FM76A, 5CM58A, 5RC84A, 5FM77A, 5CM61A, 5RC85A, 5FM78A
HP OfficeJet Enterprise Color X555
C2S11A, C2S12A, L1H45A
FS3: 3.9.9 (2309059_000585) or higher
FS4: 4.11.01 (2411097_060497) or higher
HP OfficeJet Enterprise Color MFP X585
HP OfficeJet Managed Color MFP X585
B5L04A, B5L05A, L3U40A
FS3: 3.9.9 (2309059_000591) or higher
FS4: 4.11.01 (2411097_060494) or higher
HP PageWide Color 755
4PZ47A
FS4: 4.11.01 (2411097_060481 ) or higher
HP PageWide Enterprise Color 556
G1W46A, G1W46V, G1W47A, G1W47V
FS3: 3.9.9 (2309059_000603) or higher
FS4: 4.11.01 (2411097_060498) or higher
HP PageWide Enterprise Color MFP 586
HP PageWide Enterprise Color Flow MFP 586z
G1W39A, G1W40A, G1W41A
FS3: 3.9.9 (2309059_000595) or higher
FS4: 4.11.01 (2411097_060472) or higher
HP PageWide Enterprise Color 765
J7Z04A
HP PageWide Color MFP 774
4PZ43A, 4PA44A
FS4: 4.11.01 (2411097_060499) or higher
HP PageWide Color MFP 779
4PZ45A, 4PZ46A
HP PageWide Enterprise Color MFP 780
HP PageWide Enterprise Color Flow MFP 780f
J7Z09A, J7Z10A
FS4: 4.11.01 (2411097_060485) or higher
HP PageWide Enterprise Color Flow MFP 785
J7Z11A, J7Z12A
HP PageWide Managed Color E55650
L3U44A
HP PageWide Managed Color MFP E58650dn
HP PageWide Managed Color Flow MFP E58650z
L3U42A, L3U43A
HP PageWide Managed Color E75160
J7Z06A
HP PageWide Managed Color P75250
Y3Z49A
HP PageWide Managed Color MFP E77650
HP PageWide Managed Color Flow MFP E77660z
HP PageWide Managed Color Flow MFP E77650/60z
J7Z13A, Z5G79A, J7Z08A, J7Z14A, J7Z05A, Z5G77A, J7Z03A, J7Z07A
HP PageWide Managed Color MFP P77440
Y3Z60A
HP PageWide Managed Color MFP P77940/50/60
Y3Z61A, Y3Z62A, Y3Z63A, Y3Z64A, Y3Z65A, Y3Z66A, Y3Z68A, 2GP22A, 2GP23A, 2GP25A, 2GP26A, 5ZN98A, 5ZN99A, 5ZP00A, 5ZP01A
HP Digital Sender Flow 8500 fn2 Document Capture Workstation
L2762A
FS4: 4.11.01 (2411097_060482) or higher
HP Scanjet Enterprise 8500 FN1 Document Capture Workstation
L2717A, L2719A
FS3: 3.9.9 (2309059_000620) or higher
HP ScanJet Enterprise Flow N9120 fn2 Document Scanner
L2763A
FS4: 4.11.01 (2411097_060492) or higher
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin. HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action. HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin. To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISION HISTORY : Version 1 – 17 September 2020: Initial release; Version 2 – 3 March 2022: Updated product list; Version 3 – 08 July 2022: Updated product list
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
