動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    修復在Windows更新後可能導致列印工作失敗的間歇性列印佇列錯誤 - 按一下此處
動作
正在載入...
HP LaserJet, HP PageWide - Installing a Printer Driver with a USB cable (Windows)
The HP printer must be set up before you install the printer software. If you have not already set up the printer, follow the instructions for setting up your printer hardware before installing the software.
For some printers, the high-speed USB port is disabled by default and must be enabled from the printer control panel. Use the printer control panel to enable the port before you continue: Open the Settings menu, and then select GeneralEnable Device USBEnabled.
注意:
If you plan to install the HP Universal Print Driver (UPD) for Windows, go to www.hp.com/go/upd. The UPD is designed to easily manage print environments with multiple printers on a network. The HP UPD is a good choice for a print-only printer because this driver provides ONLY print capability.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
