This document is for HP OfficeJet 8702, OfficeJet Pro 8710, 8715, 8717, 8718, and 8719 printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, install the ink cartridges, and then load paper into the input tray.
注意:If you are looking for the printer software, go to:
HP OfficeJet 8702 printer: 123.hp.com/OJ8702 HP OfficeJet Pro 8710 series printers: 123.hp.com/OJ8710
