動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    修復在Windows更新後可能導致列印工作失敗的間歇性列印佇列錯誤 - 按一下此處
動作
正在載入...
HP LaserJet Enterprise, HP PageWide Enterprise - Installing a Printer Driver with an Ethernet Cable (macOS)
Follow the steps in this document to install the printer driver (software) in macOS on a wired (Ethernet) network.
Before you begin, determine whether your control panel type is FutureSmart 3 or FutureSmart 4.
FutureSmart 3
FutureSmart 3 control panels
FutureSmart 4
FutureSmart 4 control panels
Step one: Connect the printer and find the printer's IP address
  1. Connect the network cable to the printer and to the network. Wait a few minutes for the printer to acquire a network address.
  2. Use one of the following methods (depending on your control-panel type) to locate the printer’s IP address (Example IP address: 192.168.0.1.)
    FutureSmart 3
    • Keypad control panels: View the control-panel display to see the IP address.
    • Touchscreen control panels: From the Home screen on the printer control panel, touch the Network Network button button to display the IP address or host name.
    FutureSmart 4
    • Keypad control panels: From the Home screen on the printer control panel, press the Information Information button button, then use the arrow keys to select the Ethernet menu, and then press the OK button to open the menu and view the IP address or host name.
    • Touchscreen control panels: From the Home screen on the printer control panel, touch the Information Information button icon, and then touch the Network icon to display the IP address or host name.
    If an IP address is listed, the network connection has been established. If an IP address is not listed, wait a few more minutes and try again. Note the IP address for use during software installation.
Step two: Install the printer driver
Follow these steps to install the printer driver. In addition to the following instructions, you can view a video demonstration of installing the printer software in macOS on a wired (Ethernet) network.
注意:
The printer in the video might be different from your printer model, but the steps are the same.
  1. Click one of the following links, depending on your printer model (LaserJet or PageWide):
  2. When the Install printer software screen displays, click Download.
    The computer downloads HP Easy Start.
  3. Follow the on-screen instructions to install the printer software.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
