To replace the imaging drum in HP LaserJet Pro M102, M104 (part number CF219A), and HP LaserJet Pro M203 (part number CF232A) printers, remove the toner cartridge, remove the imaging drum, install the new imaging drum, and then reinstall the toner cartridge.
Open the top cover.
描述 : Opening the top cover
Grasp the toner cartridge handle, and then pull to remove the toner cartridge.
描述 : Removing the toner cartridge
Remove the imaging drum.
描述 : Removing the imaging drum
Recycle the old imaging drum.
Remove the new imaging drum from the package and protective bag.
Align the new imaging drum with the tracks inside the printer, and then push the imaging drum until it snaps into place.
描述 : Inserting the new imaging drum
Align the toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
描述 : Reinstalling the toner cartridge
Close the top cover.
The new imaging drum is installed, and the printer is ready to print.
