動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    了解如何升級到 Windows 11
    Windows 11 升級指南
  • 反饋
動作
正在載入...
HP LaserJet Pro, Ultra Printers - First Time Printer Setup
This document is for HP LaserJet Pro MFP M148dw, M148fdw, M227d, M227fdn, M227fdw, M227sdn, LaserJet Ultra MFP M230sdn and M230fdw printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, load paper into the input tray, connect the power cable, set control panel preferences, and then download and install the printer software.
注意:
If you are looking for the printer software, go to http://123.hp.com/laserjet.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
注意:
The toner cartridge comes preinstalled in your printer. You do not need to remove the toner cartridge from the printer.
  2. Remove all tape and packing materials from the outside of the printer, and then remove the film from the printer control panel.
  3. Recycle the packing materials.
Step 2: Load plain paper in the main input tray
Load plain paper, such as A4, U.S. letter, or U.S. legal, into the main input tray.
  1. Lower the main input tray door, and then slide out the paper width guides as far as possible.
    描述 : Sliding out the paper guides
  2. Load up to 250 sheets of paper with the print side facing up and the top edge toward the printer. If you are loading pre-punched paper, load the paper with the holes toward the left side of the tray.
    描述 : Loading plain paper in the main input tray
  3. Slide in the paper guides until they touch the edge of the stack of paper.
    描述 : Sliding in the paper guides
  4. Press down on the output bin extension to open it, and then lower the output bin extender.
    • If you loaded A4 or U.S. letter-size paper, close the main input tray door.
    • If you loaded U.S. legal-size or larger paper, do not close the main input tray door.
    描述 : Lowering the output bin extender
    注意:
    Before printing or copying, select the correct paper size and paper type settings from the control panel or computer.
Step 3: Connect the power cord, and then turn on the printer
Plug the printer into a wall outlet, and then turn on the printer.
注意:
    描述 : Connecting the power cord
  2. Turn on the printer.
    The printer initializes and then calibrates itself.
  3. Wait until the printer is idle and silent before you proceed.
Step 4: Set your preferences
To set your preferences for your printer, select the instructions for your printer.
Your HP printer hardware is now set up and you can install the printing software.
Step 5: Install the printer software
Download the latest version of the printing software from 123.hp.com/laserjet, and then follow the on-screen instructions to install the software.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
