動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    了解如何升級到 Windows 11
    Windows 11 升級指南
  • 反饋
動作
正在載入...
HP Officejet Printers - Setting Up the Printer Hardware
This document is for HP Officejet 6812, 6815, 6820, Officejet Pro 6830, and 6835 e-All-in-One printers.
Complete the steps in this document to set up the printer hardware before you install the printer software on the computer.
Step 1: Unpacking the printer
Remove the printer from the box, and then remove all packing materials from the printer.
  2. Remove all tape and packing materials from the outside of the printer.
    描述 : Remove the tape and packing materials
    Image: Remove the tape and packing material
  3. Place your fingers into the slot on the left side of the printer, and then gently lift up to open the cartridge access door.
    描述 : Place your fingers in the slot on the left side of the printer
    Image: Slot on the left side of the printer
  4. Remove all tape and packing materials from inside the printer, including from the carriage, paper tray, and scanner bed.
    描述 : Remove all packing materials from inside the printer
    Image: Remove all packing materials from inside the printer
  5. Close the cartridge access door.
    描述 : Close the cartridge access door
    Image: Close the cartridge access door
  6. Discard or recycle the packing materials.
Step 2: Checking the contents of the box
Make sure that you remove all hardware and materials from the box.
Step 3: Loading paper into the paper tray
Before you install the cartridges, load the tray with plain white paper, and then pull out the paper tray extender.
  1. Lift the output tray.
    描述 : Lift the output tray
    Image: Lift the output tray
  2. Grasp the handle on the input tray, and then pull out the tray.
    描述 : Pull out the paper tray
    Image: Pull out the paper tray
  3. Slide out the paper width guides as far as possible.
    描述 : Slide out the paper width guides
    Image: Slide out the paper width guides
  4. Insert plain white paper in the paper tray.
      敬告:
    Do not fill the paper higher than the yellow, dotted lines on the sides of the paper tray.
    描述 : Load the paper
    Image: Load the paper
  5. Slide in the paper width guides until they rest against the edge of the stack of paper.
  6. Push the tray into the printer until it locks in place.
    描述 : Push in the paper tray
    Image: Push in the paper tray
  7. Lower the output tray, pull out the tray extender, and then lift the paper catch.
    描述 : Pull out the tray extender
    Image: Pull out the tray extender and lift the paper catch
Step 4: Connecting the power cord and setting your preferences
Plug the printer into a power source, turn on the printer, and then select your preferences.
  敬告:
Do not connect a USB cable at this time. The printer prompts you to connect the USB during the software installation.
  1. Connect the power cord to the rear of the printer.
  2. Plug the other end of the power cord into an electrical outlet.
    描述 : Connect the power cord
    Image: Plug the power cord into the printer and the electrical outlet
  3. Press the Power button to turn on the printer.
  4. On the printer control panel, touch your preferred language, and then touch Continue to confirm your choice.
  5. Touch the display to select your specific country/region, and then touch Continue Setup.
  6. Scroll the display to set the month, day, and year.
  7. Scroll the display to set the time, and then touch Continue.
  8. Touch the Settings icon to select a 24-hour format (optional).
  9. Touch Continue.
Step 5: Installing the cartridges
For initial setup, install the SETUP cartridges that came with your printer.
  敬告:
Failure to install the SETUP cartridges that came with the printer causes a cartridge error.
  1. Place your fingers into the slot on the left side of the printer, and then gently lift up to open the cartridge access door. The carriage moves to the cartridge access area. Wait several seconds until the carriage is idle and silent before you continue.
  2. Remove a cartridge from its package, and then pull the orange pull-tab straight back.
      敬告:
    Make sure that you remove the orange pull-tab and plastic wrap completely before you remove the orange cap in the next step. Otherwise, ink might leak from the cartridge. When you remove the plastic wrap, the paper label on the top of the cartridge tears slightly, which is necessary to properly vent the cartridge.
    描述 : Pull the orange tab on the wrapper straight back
    Image:  Pull the orange tab straight back
  3. Hold the cartridge by its sides, and then twist the protective orange cap counter-clockwise to snap it off the cartridge.
    描述 : Twist the orange cap to snap it off the cartridge
    Image: Twist the orange cap to snap it off the cartridge
      敬告:
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  4. Turn the cartridge so that the cartridge contacts face downward, and then match the label color with the color dot on the carriage.
  5. Slide the cartridge into its slot, and then gently press the cartridge down until it clicks into place.
    描述 : Install the cartridge
    Image: Install the cartridge
  6. Repeat these steps to install all the new cartridges.
  7. Close the cartridge access door.
  8. Wait for the printer to align the cartridges. After the alignment is complete, the printer prints an alignment page.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 香港特別行政區
動作
正在載入...
