動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    我們正在更新我們的網站。
    如果您在此期間遇到錯誤,請稍後再試。
    資料
    修復在Windows更新後可能導致列印工作失敗的間歇性列印佇列錯誤 - 按一下此處
動作
正在載入...
HP Enterprise - Update the firmware
Similar to service packs for operating systems, HP provides firmware updates for printers to help address any known issues and add new features throughout the support life of the printer.
To make sure the printer is up to date, HP recommends updating the firmware for HP Enterprise and HP Managed printers. See Applicable printers.
Update the firmware
There are four supported methods to perform a firmware update on this printer depending on whether the printer is in a ready state or an error state:
About firmware downgrades
If you attempt to downgrade the firmware from a remote location to a version older than FutureSmart Version 4, the downgrade will fail and you will receive a 99.02.32 control panel error and a 33.05.09 event log.
This is due to a new security feature that requires someone to be present at the printer in order to perform a firmware downgrade and prevents HP SureStart printers from being downgraded remotely. For more information about this feature, go to Embedded Security features.
HP recommends using the latest firmware available but if a downgrade from HP FutureSmart 4 to HP FutureSmart 3 is absolutely necessary, then use the Preboot menu and avoid any errors.
注意:
If you downgrade the printer firmware, all solutions, stored jobs, and current settings will be lost. The machine will be reset back to factory settings.
Applicable printers
This document applies to the following printer models:
  • HP LaserJet Enterprise
  • HP LaserJet Managed
  • HP Officejet Enterprise
  • HP PageWide Enterprise
  • HP PageWide Managed
For an older small business HP LaserJet printer, use the WJA method or go to HP LaserJet - Update the firmware.
For an HP LaserJet Pro printer, use the WJA method or go to HP LaserJet Pro - Update the firmware.
Print a Configuration Page
To determine the current firmware version that is installed on the printer, print a configuration page using one of the following methods.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
