This document is for HP printers that support web-connected printing services.
If you are unable to register your printer to your account, or you want to set up a new account with HP, visit the HP Smart website and register your printer. Registering allows you to access additional web printing services, such as HP ePrint and HP Instant Ink.
If you are setting up HP Smart for the first time, you must create or sign in to an HP account.
If you update to the latest version, you do not have to create or sign in to an HP account except in these cases:
You install an HP+ printer.
You install HP Smart on a new device, or you remove and reinstall the app.
注意:The HP Smart website availability depends on your country/region. To see if the website is available for your country/region, go to HP Smart, and then select the country/region and language menu.
If you registered with the HP Smart website during printer setup, your printer might already be added. Go to HP Smart, and then sign in to your account.
If your printer is listed, skip to Setting up web-connected printing services.
If you have an HP+ printer, go to 123.hp.com to download the printer software, and then follow the prompts to set up your printer and sign in to your HP account. You cannot manually add an HP+ printer to your account using a printer code.
If your printer is not listed, continue with these steps.
