動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP Deskjet, Photosmart 6520 Printers - Replacing Ink Cartridges
This document is for HP Deskjet Ink Advantage 6525 and HP Photosmart 6520, 6521, and 6525 e-All-in-One printers.
Review steps to replace existing ink cartridges and get information on which cartridges work with your printer and where to purchase them.
Replace the ink cartridges
Remove existing ink cartridges and replace them with new ones.
  1. Turn on the printer.
  2. Open the cartridge access door. The carriage moves to the access area.
  3. Press the tab on the front of the cartridge inward to release it, and then pull up on the cartridge to remove it from the slot.
    Remove the cartridge from the slot
  4. Pull the orange tab to remove the new cartridge from the plastic wrap.
      敬告:
    Make sure to remove the orange pull tab and plastic wrap completely before you twist the orange cap in the next step. Otherwise, ink might leak from the cartridge. When you remove the plastic wrap, the paper label on the top of the cartridge tears slightly, which is necessary to properly vent the cartridge.
    Remove the new cartridge from the plastic wrap
  5. Twist the orange cap counter clockwise until it snaps off the new cartridge.
    Remove the orange cap from the new cartridge
  6. With the nozzle and contacts facing down, slide the cartridge into its slot. Press down on the cartridge until it is firmly seated.
    Insert the cartridge
  7. Close the cartridge access door.
Frequently asked questions
Review frequently asked questions about replacing your ink cartridges.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
