動作
正在載入...
歡迎來到惠普客戶支援
動作
正在載入...
動作
正在載入...
  • 資料
    關於最近電腦產品安全隱患的資訊
    惠普發現最近的隱患通常被稱為“Spectre”和“Meltdown”。惠普發佈了一個針對這些問題的韌體安全公告和受影響操作系統列表。我們將繼續更新公告,煩請您經常檢視公告,獲得更多有用的資訊。
動作
正在載入...
HP 筆記型電腦 - 按一下連結後 Internet Explorer 可能會開啟空白視窗
問題
在 Internet Explorer 中按一下連結可能造成空白視窗開啟。
解決方法
  1. 確定已關閉所有 Internet Explorer 視窗。
  2. 開啟「記事本」,然後貼上以下文字:
    @echo off echo. echo IEREREG Version 1.07 for IE8 27.03.2009 echo by Kai Schaetzl http://iefaq.info echo installs and registers (if suitable) all DLLs known to be used by IE8. echo should only take a few seconds, but please be patient echo. REM ****************************** echo registering IE files REM IE files (= part of setup) regsvr32 /s /i browseui.dll REM regsvr32 /s /i browseui.dll,NI (unnecessary) regsvr32 /s corpol.dll regsvr32 /s dxtmsft.dll regsvr32 /s dxtrans.dll REM simple HTML Mail API regsvr32 /s "%ProgramFiles(x86)%\internet explorer\hmmapi.dll" REM group policy snap-in regsvr32 /s ieaksie.dll REM smart screen regsvr32 /s ieapfltr.dll REM ieak branding regsvr32 /s iedkcs32.dll REM dev tools regsvr32 /s "%ProgramFiles(x86)%\internet explorer\iedvtool.dll" regsvr32 /s iepeers.dll REM Symptom: IE8 closes immediately on launch, missing from IE7 regsvr32 /s "%ProgramFiles(x86)%\internet explorer\ieproxy.dll" REM no install point anymore REM regsvr32 /s /i iesetup.dll REM no reg point anymore REM regsvr32 /s imgutil.dll regsvr32 /s /i /n inetcpl.cpl REM no install point anymore REM regsvr32 /s /i inseng.dll regsvr32 /s jscript.dll REM license manager regsvr32 /s licmgr10.dll REM regsvr32 /s msapsspc.dll REM regsvr32 /s mshta.exe REM VS debugger regsvr32 /s msdbg2.dll REM no install point anymore REM regsvr32 /s /i mshtml.dll regsvr32 /s mshtmled.dll regsvr32 /s msident.dll REM no reg point anymore REM regsvr32 /s msrating.dll REM multimedia timer regsvr32 /s mstime.dll REM no install point anymore REM regsvr32 /s /i occache.dll REM process debug manager regsvr32 /s "%ProgramFiles(x86)%\internet explorer\pdm.dll" REM no reg point anymore REM regsvr32 /s pngfilt.dll REM regsvr32 /s /i setupwbv.dll (not there anymore!) regsvr32 /s tdc.ocx regsvr32 /s /i urlmon.dll REM regsvr32 /s /i urlmon.dll,NI,HKLM regsvr32 /s vbscript.dll REM VML renderer regsvr32 /s "%CommonProgramFiles%\microsoft shared\vgx\vgx.dll" REM no install point anymore REM regsvr32 /s /i webcheck.dll regsvr32 /s /i /n wininet.dll REM ****************************** echo registering system files REM additional system dlls known to be used by IE REM added 11.05.2006 Symptom: Add-Ons-Manager menu entry is present but nothing happens regsvr32 /s extmgr.dll REM added 12.05.2006 Symptom: Javascript links don't work (Robin Walker) .NET hub file regsvr32 /s mscoree.dll REM added 23.03.2009 Symptom: Find on this page is blank regsvr32 /s oleacc.dll REM added 24.03.2009 Symptom: Printing problems, open in new window regsvr32 /s ole32.dll REM mscorier.dll REM mscories.dll REM Symptom: open in new tab/window not working regsvr32 /s actxprxy.dll regsvr32 /s asctrls.ocx regsvr32 /s cdfview.dll regsvr32 /s comcat.dll regsvr32 /s /i /n comctl32.dll regsvr32 /s cryptdlg.dll regsvr32 /s /i /n digest.dll regsvr32 /s dispex.dll regsvr32 /s hlink.dll regsvr32 /s mlang.dll regsvr32 /s mobsync.dll regsvr32 /s /i msieftp.dll REM regsvr32 /s msnsspc.dll #no entry point regsvr32 /s msr2c.dll regsvr32 /s msxml.dll regsvr32 /s oleaut32.dll REM regsvr32 /s plugin.ocx #no entry point regsvr32 /s proctexe.ocx REM plus DllRegisterServerEx ExA ExW ... ? regsvr32 /s /i scrobj.dll REM shdocvw.dll hasn't been updated for IE7 and IE8, it still registers itself for the Windows Internet Controls regsvr32 /s /i shdocvw.dll regsvr32 /s sendmail.dll REM ****************************** REM PKI/crypto functionality REM initpki can take very long to run and is rarely a problem REM if there are problems with crypto, SSL, certificates REM remove the three following REMs from the lines REM echo We are almost done except one crypto file REM echo but this will take very long, be patient! REM regsvr32 /s /i:A initpki.dll REM ****************************** REM tabbed browser, do at the end, why originally with /n ? regsvr32 /s /i ieframe.dll REM ****************************** echo correcting bugs in the registry REM do some corrective work REM Symptom: new tabs page cannot display content because it cannot access the controls (added 27. 3.2009) REM This is a result of a bug in shdocvw.dll (see above), probably only on Windows XP reg add "HKCR\TypeLib\{EAB22AC0-30C1-11CF-A7EB-0000C05BAE0B}\1.1\0\win32" /ve /t REG_SZ /d %systemroot%\system32\ieframe.dll /f REM ****************************** echo all tasks have been finished echo.  pause
      注意:
    以上文字適用於 Windows 64 位元版本。 若是使用 Windows 32 位元版本,請在貼入上方文字後,將 %ProgramFiles(x86)% 取代為 %ProgramFiles%
  3. 將「記事本」文件以 .bat 副檔案的形式儲存在桌面上。 關閉「記事本」。
  4. 用滑鼠右鍵按一下 .bat 檔案,然後選擇以系統管理員身分執行
動作
正在載入...
動作
正在載入...
詢問社區!
支援論壇
支援論壇
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
