動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP Compaq 8200 Elite Small Form Factor PC - Removing and Replacing the Memory
This document is provided to assist in removing and replacing the memory for the HP Compaq 8200 Elite Small Form Factor PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Parts required
注意:
The replacement part number will vary depending on the memory that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1GB, PC3-10600, DDR3-1333 MHz, 240-pins,non-ECC, unbuffered DIMM (Dual In-Line Memory Module)
635802-001 (Modified)
Yes
2GB, PC3-10600, DDR3-1333 MHz, 240-pins,non-ECC, unbuffered DIMM (Dual In-Line Memory Module)
635803-001 (Modified)
Yes
4GB, PC3-10600, DDR3-1333 MHz, 240-pins, non-ECC, unbuffered DIMM (Dual In-Line Memory Module)
585157-001 (Modified)
Yes
注意:
Summary of instructions
To view a video demonstrating the procedure for removing the memory, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory from the menu on the upper left hand side of the screen.
Click here to view the memory removal video (right-click on the link to open in a new window/tab).
Memory removal
      敬告:
  2. Rotate the drive cage to the up position.
  3. Push down and out on the memory socket latches to release the memory module.
  4. Pull the memory module up and out of the socket.
Memory replacement
  1. Ensure that the memory socket latches are pushed down and away from the memory socket.
  2. Match the notch on the memory module with the key on the memory socket.
  3. Push the module down firmly into the socket until the latches snap into place and the module is fully seated.
  4. Rotate the drive cage to the down position.
Parts return
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
