動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP ProBook 4510s Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the Hard Disk Drive for the HP ProBook 4510s Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P000, P00 and P1) screwdrivers
Parts required
注意:
The replacement part number will vary depending on the Hard Disk Drive that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
160GB SATA hard drive
536411-001
Yes
250GB SATA hard drive
536412-001
Yes
320GB SATA hard drive
536413-001
Yes
500GB SATA hard drive
536414-001
Yes
120GB 7200 RPM Primary Hard Drive
AH920AA
Yes
250GB 5400 RPM Primary SATA Hard Drive
AK072AA
Yes
注意:
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Hard Disk Drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Hard Disk Drive from the menu on the upper left hand side of the screen.
Click here to view the Hard Disk Drive removal video (right-click on the link to open in a new window/tab).
      敬告:
      敬告:
    Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
    Click Here for instructions to remove the Battery, Switch cover, Keyboard and Palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Parts return
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
