動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP EliteBook 2530p Notebook PC - Removing and Replacing the Primary Memory Board
This document is provided to assist in removing and replacing the Primary memory board for the HP EliteBook 2530p Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screwdriver
Parts required
注意:
The replacement part number will vary depending on the Primary memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
4 GB, 800 MHz, 200-pin, PC2-6400, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
492572-001 (Modified)
Yes
2 GB, 800 MHz, 200-pin, PC2-6400, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
492571-001 (Modified)
Yes
1 GB, 800 MHz, 200-pin, PC2-6400, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
492570-001 (Modified)
Yes
注意:
Summary of instructions
To view a video demonstrating the procedure for removing the Primary memory board, click on the link below. Or use the product video listing on the HP Services Media Library, then select Primary memory board from the menu on the upper left hand side of the screen.
Click here to view the Primary memory board removal video (right-click on the link to open in a new window/tab).
      敬告:
  2. Remove the 3 mm P1 Phillips-head screw that secures the metal primary memory board shield to the base enclosure.
  3. Lift the right edge of the primary memory board shield and slide it to the right to remove.
  4. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
      敬告:
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the primary memory board by the edges and pull gently to remove it.
  6. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
      敬告:
  4. Press the primary memory board down to latch the arms.
  5. Toe the left edge of the primary memory board shield into the base enclosure and lower it into position.
  6. Replace the 3 mm P1 Phillips-head screw that secures the metal primary memory board shield to the base enclosure.
Parts return
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
