動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP EliteBook 2530p Notebook PC - Removing and Replacing the Bluetooth Module
This document is provided to assist in removing and replacing the Bluetooth module for the HP EliteBook 2530p Notebook PC.
Minimum skill level
Tools required
  • P0 Phillips-head screwdriver
  • P1 Phillips-head screwdriver
Parts required
注意:
The replacement part number will vary depending on the Bluetooth module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Integrated wireless Bluetooth 2.0 module
483113-001 (Modified)
Yes
注意:
Summary of instructions
To view a video demonstrating the procedure for removing the Bluetooth module, click on the link below. Or use the product video listing on the HP Services Media Library, then select Bluetooth module from the menu on the upper left hand side of the screen.
Click here to view the Bluetooth module removal video (right-click on the link to open in a new window/tab).
      敬告:
  2. Loosen the captive P1 Phillips-head screw that secures the Bluetooth module cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the inside edge of the Bluetooth module cover and turn it upside down.
  4. Remove the 3 mm P0 Phillips-head screw that secures the Bluetooth module to the cover.
  5. Disconnect the Bluetooth module cable from the Bluetooth module.
  6. Place the Bluetooth module in a static dissipative bag.
Bluetooth module replacement
  1. Remove the Bluetooth module from the static dissipative bag.
  2. Reconnect the Bluetooth module cable to the Bluetooth module.
  3. Place the Bluetooth module into position on the cover.
  4. Replace the 3 mm P0 Phillips-head screw that secures the Bluetooth module to the cover.
  5. Toe the Bluetooth module cover into the base enclosure and lower it into position.
  6. Tighten the captive P1 Phillips-head screw that secures the Bluetooth module cover to the bottom of the notebook.
Parts return
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
