動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP EliteBook 2530p Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the Hard disk drive for the HP EliteBook 2530p Notebook PC.
Minimum skill level
Tools required
P1 Phillips-head screwdriver
Parts required
注意:
The replacement part number will vary depending on the Hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
160-GB, 5400-rpm hard drive
503732-001 (Modified)
Yes
120 GB SATA hard disk drive (primary) - 5,400 RPM, 4.57 cm (1.80 inhes) form factor - Includes bracket
492560-001 (Modified)
Yes
80 GB SATA hard disk drive (primary) - 5,400 RPM, 4.57 cm (1.80 inches) form factor - Includes bracket
492565-001 (Modified)
Yes
80 GB solid-state hard drive (primary) - 4.57 cm (1.80 inhes) form factor
492566-001 (Modified)
Yes
Primary hard drive connector board - For 4.57 cm (1.80 inches) drives
495026-001 (Modified)
Yes
注意:
Summary of instructions
To view a video demonstrating the procedure for removing the Hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select 1.8 inch Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the Hard disk drive removal video (right-click on the link to open in a new window/tab).
      敬告:
  2. 注意:
    The notebook can have a 1.8 inches hard disk drive installed in a compartment on the bottom of the notebook or a 2.5 inches hard disk drive installed in the optical drive bay.
  3. Loosen the two captive P1 Phillips-head screws that secure the 1.8 inches hard disk drive cover to the bottom of the notebook.
  4. Use your finger or a flat-bladed tool to lift the edge of the 1.8 inches hard disk drive cover and remove it.
  5. Loosen the two captive P1 Phillips-head screws that secure the 1.8 inches hard disk drive bracket to the base enclosure and remove the bracket.
  6. Remove the 5 mm P1 Phillips-head screw that secures the 1.8 inches hard disk drive connector to the base enclosure.
  7. Carefully lift the inside edge of the 1.8 inches hard disk drive and slide it toward the front of the notebook until it clears the plastic tab on the rear edge of the compartment.
  8. Swing the end of the 1.8 inches hard disk drive up and disconnect the 1.8 inches hard disk drive from the 1.8 inches hard disk drive connector.
  9. Place the 1.8 inches hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the 1.8 inches hard disk drive from the static dissipative bag.
  2. Reconnect the 1.8 inches hard disk drive to the 1.8 inches hard disk drive connector.
  3. Carefully toe the rear edge of the 1.8 inches hard disk drive under the plastic tab on the rear edge of the compartment.
  4. Lower the front edge of the 1.8 inches hard disk drive into the base enclosure.
  5. Replace the 5 mm P1 Phillips-head screw that secures the 1.8 inches hard disk drive connector to the base enclosure.
  6. Place the 1.8 inches hard disk drive bracket into the base enclosure and tighten the two captive P1 Phillips-head screws that secure the bracket.
  7. Toe the 1.8 inches hard disk drive cover into the base enclosure and lower it into position.
  8. Tighten the two captive P1 Phillips-head screws that secure the 1.8 inches hard disk drive cover to the bottom of the notebook.
Parts return
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
