動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
  • 資料
    我們正在更新我們的網站。
    如果您在此期間遇到錯誤,請稍後再試。
    資料
    修復在Windows更新後可能導致列印工作失敗的間歇性列印佇列錯誤 - 按一下此處
動作
正在載入...
HP EliteBook 2530p Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the Battery for the HP EliteBook 2530p Notebook PC.
Minimum skill level
Parts required
注意:
The replacement part number will vary depending on the Battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery (Primary) - 9-cell lithium-ion (Li-Ion), 83Wh
492550-001 (Modified)
No
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 55Wh
492549-001 (Modified)
No
Battery (Primary) - 3-cell lithium-ion (Li-Ion), 31Wh
492548-001 (Modified)
No
注意:
Summary of instructions
To view a video demonstrating the procedure for removing the Battery, click on the link below. Or use the product video listing on the HP Services Media Library, then select Battery from the menu on the upper left hand side of the screen.
Click here to view the Battery removal video (right-click on the link to open in a new window/tab).
Battery removal
      敬告:
  2. Slide both battery locking latches toward the outside of the notebook to partially eject the battery.
  3. Slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until it is properly seated and the locking latches click.
Parts return
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
