動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP Photosmart D5345, D5360, D5363 and D5368 printers - Installing Print Cartridges
This document describes how to install and align the print cartridge in the printer.
Step one: Install the print cartridge
To install print cartridges, do the following:
  1. Open the print cartridge door.
    The print carriage moves to the far right side of the HP Photosmart printer.
    描述 : Opening the print cartridge door
  2. Remove the new print cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab.
      描述 : Handling the print cartridge
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
      敬告:
    Do not touch the copper-colored contacts or ink nozzles. Also, donot re-tape the print cartridges. Doing so can result in clogs, ink failure, and badelectrical connections.
    描述 : Do not touch copper-colored contacts or ink nozzles
    If you are installing the tri-color print cartridge, slide it into the left slot.
    If you are installing a black, photo, or gray photo print cartridge, slide it into the rightslot.
      描述 : The right slots for cartridges
    1. Print cartridge slot for the tri-color print cartridge
    2. Print cartridge slot for the black and photo print cartridges
    描述 : Installing the cartridge
  3. Close the print cartridge door.
    描述 : Closing the print cartridge door
    After successful installation, the HP Photosmart printer prints a print cartridgealignment page.
  4. When prompted, ensure plain white paper is loaded in the input tray, and then pressOK.
  5. The HP Photosmart printer prints a test page, aligns the print head, and calibrates the printer.Recycle or discard the page.
    A success or failure message appears.
  6. Press OK to continue.
Step two: Align print or ink cartridges
As soon as the cartridges are installed, the HP Photosmart printer prompts youto align and calibrate the print cartridges. Makesure you align the print cartridges when prompted to ensure excellent print quality.
  1. When prompted, load letter or A4 unused plain white paper in the input tray,and then press OK.
  2. The HP Photosmart printer prints a test page, aligns the print head, and calibrates the printer.Recycle or discard the page.
    注意:
    If you load colored paper in the input tray when you align theprinter, the alignment will fail. Load unused plain white paper into the input tray,and then try the alignment again.
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
