動作
正在載入...
HP 顧客貼心服務 - 知識庫
動作
正在載入...
動作
正在載入...
動作
正在載入...
HP PSC 1310 Series - Installing Cartridges
注意:
Install the cartridges as soon as possible after you remove the tape. Remove only the tape! Do not attempt to remove the copper strip.
描述 : If you have a new print cartridge, remove the tape
描述 : Make sure the printer is turned on
描述 : Open both doors on the printer, then wait a moment for the cartridge carriage to come to the center
描述 : Place the tri-color cartridge in the left slot at a slight angle, then press up and forward until the cartridge snaps into position
描述 : Place the black or photo cartridge in the right slot at a slight angle, then press up and forward until the cartridge snaps into position
描述 : Close the gray door
動作
正在載入...
動作
正在載入...
動作
正在載入...
國家/地區: 中國香港
動作
正在載入...
