This document provides the specifications for the HP Scanjet 4600 and 4670 digital flatbed scanner series, the transparent materials adapter (TMA), and the environmental requirements.
Name
Scanner type
Flatbed
Weight (without holder)
1.4 kg (3.1 pounds)
Holder weight
Maximum item size (without holder)
410 x 300 x 17 mm (16.14 x 11.81 x 0.67 inches)
Scanning element
2400 ppi (pixels per inch) linear sensor
Interface
USB 2.0 Hi-Speed
Optical resolution
2400 x 2400 ppi
Selectable resolution
12 dpi to 999,999 enhanced dpi at 100 percent scaling
AC line voltage
Power consumption
For power consumption data, see the regulatory_supplement.htm file on
the HP Photo & Imaging software CD.
The HP Scanjet 4600 and 4670 scanners are ENERGY STAR compliant. As an
ENERGY STAR partner, Hewlett-Packard Company has determined that this
product meets the ENERGY STAR guidelines for energy efficiency.
Name
Media types
One 35 mm slides or one 35 mm negative strip
Media capacity side
Slide: 1.05 to 1.9 mm thick and 49.8 to 50.8 mm on any side
Size
24 x 106.8 x 168 mm (.095 x 4.2 x 6.6 inches)
0.2 kg (0.44 pounds)
Power requirements
12.0 VDC, 340 mA, 4.22 watts < (supplied by scanner)
Name
Temperature
Operating the scanner and TMA: 10 to 35 degrees C (50 to 95 degrees F)
Storage: -40 to 70 degrees C (-40 to 158 degrees F)
Relative humidity
Operating the scanner, APF, and TMA: 15 percent to 80 percent
non-condensing 10 to 35 degrees C (50 to 95 degrees F)
Storage: up to 90 percent at 0 to 65 degrees C or (32 to 149 degrees F)
