    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
    Fix HP Printer issue on macOS
OMEN by HP 15-dh0037no Product Specifications
8PK70EA
Intel® Core™ i9-9880H (2.3 GHz base frequency, up to 4.8 GHz base with Intel® Turbo Boost Technology, 16 MB cache, 8 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
36 x 26 x 2.04 cm
2.32 kg
200 W Smart AC power adapter
6-cell, 69 Wh Li-ion polymer
Battery life mixed usage
Up to 4 hours and 45 minutes
Video Playback Battery life
Up to 3 hours and 15 minutes
Audio by B&O; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Country/Region: Hong Kong SAR
