HP LaserJet Enterprise MFP M631, M632, M633 - Removal and replacement: Hard-disk drive (HDD)
This document provides the procedures to remove and replace the hard-disk drive (HDD).
Mean time to repair: 5 minutes
Service level: Basic
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Hard-disk drive (HDD) part number
5851-6712
B5L29-67903
320 GB hard disk drive kit
Secure hard disk drive kit
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
No post service test is available for this assembly.
  1. Remove the formatter cover.
    1. To remove the formatter cover, do the following:
      • On the formatter cover, release two thumb screws (callout 1).
      • Slide the formatter cover in the direction indicated by the arrow (callout 2) and remove it.
      Figure : Release two thumb screws and remove the formatter cover
  2. Remove the hard-disk drive (HDD).
    1. Do the following:
      • Release the hard-disk drive (HDD) locking connector (callout 1).
      • Pinch the retainer (callout 2) to release it.
        Electrostatic sensitive (ESD) parts. Always touch the sheet‑metal chassis to provide a static ground before touching an ESD‑sensitive part.
      Figure : Release the HDD locking connector and pinch the retainer to release it
    2. Do the following:
      • Rotate the connector end of the HDD out and away from the formatter (callout 1).
      • Slide the HDD away from the formatter cage, in the direction indicated by the arrow (callout 2), and remove it.
      Figure : Rotate the HDD away from the formatter and remove the HDD
  3. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
    3. To install an assembly, reverse the removal steps.
  4. Install the hard-disk drive (HDD).
    1. Before proceeding, take note of the location of the slot (callout 1) in the sheet metal where the HDD cradle mounting tab (callout 2) must be installed.
      Figure : Locate the slot where the HDD mounting tab is installed
      • Insert the HDD cradle mounting tab into the slot in the sheet metal.
      • Slide the HDD toward the formatter cage (callout 1) to fully install the tab in the sheet metal.
      • Rotate the connector end (callout 2) of the HDD toward the formatter.
      Figure : Install the tab into the slot and rotate the connector end
    3. Make sure that the locking connector (callout 1) latches and that the standoff (callout 2) engages with the slot in the formatter.
      It might be necessary to pinch the retainer to engage it with the slot.
      Figure : The locking connector is latched and the standoff is engaged with the slot
  5. Install the formatter cover.
    1. Slide the formatter cover onto the printer in the direction indicated by the arrow (callout 1), and then tighten two thumb screws (callout 2).
      The image shown is for the M631/M632/M633 printers, however the install process is the same for M607/M608/M609 printers.
      Figure : Slide on the formatter cover and tighten two thumb screws
Country: Flag United Kingdom
