Chargement...
Chargement...
Chargement...
    Avez-vous besoin d'aide avec Windows 11 ?
    Vérifiez les informations sur la compatibilité, la mise à niveau et les correctifs disponibles auprès de HP et de Microsoft. Centre d'assistance Windows 11
    Problèmes de son ou de l’audio ? Essayez notre outil automatisé, HP Audio check!
  • Avis
Chargement...
HP Neverstop Laser MFP 1200 - First Time Printer Setup
This document is for HP Neverstop Laser MFP 1200a, 1200n, 1200nw, 1200w, 1201n, 1202nw, and 1202w printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, uncover the imaging drum, load paper into the input tray, connect the power cord, and then download and install the printer software.
Remarque :
If you are looking for the printer software, go to 123.hp.com.
Step 1: Unpack the printer
Take the printer out of the box, and then remove all packing materials.
  1. Remove the printer from the box, and then remove all tape and packing materials from the outside of the printer.
    Removing the tape from the printer
  2. Lift the scanner, and then open the top cover.
    Lifting the scanner and top cover
  3. Pull the orange handle toward you to remove the protective sheet from the imaging drum.
    Pulling the orange handle
  4. Close the top cover, and then lower the scanner.
    Closing the top cover and lowering the scanner
  5. Recycle all packing materials.
Step 2: Load paper
Install the input tray, and then load plain white paper.
  1. Insert the input tray into its slot.
    Installing the input tray
  2. Slide out the paper guides as far as possible.
    Sliding out the paper guides
  3. Load a stack of plain white paper.
    Loading paper
  4. Slide the paper guides in until they touch the edges of the paper.
    Sliding the paper guides in
  5. Slide the input tray cover onto the tray.
    Placing the input tray cover on the input tray
  6. Pull out the output bin extension.
    Pulling out the output bin extension
Step 3: Turn on the printer and install software
Connect your printer to a power source, and then install the printer software or the HP Smart app.
  1. Plug the printer into an electrical outlet.
    The printer turns on automatically.
    Remarque :
    Connecting the power cord
  2. Go to 123.hp.com to download the latest version of the printing software.
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
