Dual channel (2 DIMMs per channel) memory architecture
Four DDR4 UDIMM (288-pin) sockets
Supports PC4-19200 (DDR4-2400)
Supports 4 GB and 8 GB DDR4 UDIMMs
Supports up to 4 GB on 32-bit systems
Remarque :
32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 32 GB (unbuffered) on 64-bit computers
Remarque :
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
Video
Integrated graphics
Integrated Intel HD Graphics 630
Remarque :
Integrated video is not available if a graphics card is installed.
Audio
Integrated audio
Audio Codec: ALC3863-CG
High Definition (Azalia) 5.1 channel audio support
Remarque :
The motherboard supports 5.1 surround sound. If the computer does not have the required audio jacks for a 5.1 configuration, additional hardware is required to use 5.1 surround sound.
Audio jack presence detection
Remarque :
An internal speaker is not included with integrated audio. External speakers or headphones are required to hear sound.
Remarque :
Integrated audio is not available if a sound card is installed.
Network
LAN: 1000BASE-T
Technology: Realtek RTL8161
Data transfer speeds: up to 10/100/1000 Mb/s
Transmission standards: 1000BASE-T Ethernet
Expansion Slots
Two PCI Express x16 physical slot (Gen 3.0), each slot with x8 bus lanes
Remarque :
One PCI Express slot is disabled.
One M.2 socket 1, key A
One M.2 socket 3, key M
Serial ATA (SATA) Connectors
Five Serial ATA (SATA) connectors
Figure : SATA connectors
SATA 1
SATA 2 (disabled)
SATA 3
SATA 4 (disabled)
SATA 5
I/O Ports and Jumpers
Back I/O ports
Remarque :
The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
Figure : Tampa2 back I/O panel
Optical SPDIF connector
DisplayPort
HDMI out
USB 2.0: 2
USB 3.1: 4
LAN (Ethernet)
Audio: Line in
Audio: Line out
Audio: Microphone
Jumpers
Figure : Clear CMOS and clear password jumpers in the default positions
