Chargement...
Chargement...
Chargement...
    Résoudre les problèmes de mises à jour de Windows 10
    Résoudre les problèmes de mise à jour de Windows 10 sur une imprimante ou un PC HP – cliquez ici
Chargement...
Removing and Replacing the Battery for HP ENVY 17-k000 Notebook PCs
This document applies to HP ENVY 17-k000 notebook computers.
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  Avertissement :
Before starting, power off the computer and wait for components to cool before starting these procedures.
  Attention :
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  Attention :
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
Remarque :
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP ENVY 17-k000 notebook computers.
Removing the battery
Follow the steps in this section to remove the battery.
  Avertissement :
Step 1
Find the battery lock latch identified by the lock icon on the bottom of the computer and slide it to the unlock position.
Sliding the battery lock latch
Step 2
Find the battery release latch identified by the battery icon and slide the battery release latch to the release position to partially eject the battery.
Sliding the battery release latch to release the battery
Step 3
Lift the front edge of the battery and remove the battery from the battery bay.
Lifting and removing the battery
Replacing the battery
Use the steps in this section to replace the battery.
Step 1
Insert the rear edge of the battery into the battery bay and lower the battery until it is properly seated and the battery release latch clicks.
Replacing the battery into its bay
Step 2
Slide the battery lock to the lock position to secure the battery.
Sliding the battery latch lock into the lock position
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
