Chargement...
Chargement...
Chargement...
    Résoudre un problème d’imprimante HP sur Mac
    Un message « [un composant logiciel] va endommager votre ordinateur » s’affiche lors de l’impression ou de l'installation - Cliquez ici
Chargement...
HP 248 G1 Notebook PC - Specifications
Physical specifications
Specification
Dimensions (W x D x H)
24.5 x 34.7 x 2.3 cm (9.7 x 13.7 x 0.91 in)
Starting at 1.9 kg (4.19 lb) weight will vary by configuration
Memory specifications
Specification
Memory
4GB 1600-MHz DDR3 SDRAM (1 x 4 GB)
Memory slots
2 SODIMM
Storage specifications
Specification
Internal drive
500GB 5400 rpm SATA
Optical drive
DVD+/-RW SuperMulti DL
Graphics specifications
Specification
Graphics
Intel HD Graphics 4400
14-inch diagonal LED-backlit HD anti-glare (1366 x 768)
Power specifications
Specification
Power supply
65-W Smart AC adapter
4-cell (41 WHr) Li-Ion
Operating voltage and current1
  • 19.5 V dc @ 4.62 A – 90 W
  • 19.5 V dc @ 3.33 A – 65 W
Remarque :
1: This product is designed for IT power systems in Norway with phase-to-phase voltage not exceeding 240 V rms.
The computer operating voltage and current can be found on the system regulatory label.
Communications specifications
Specification
Wireless
802.11a/b/g/n (2 x 2) WiFi and Bluetooth 4.0 combo
Realtek Ethernet (10/100/1000)
Environmental specifications
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity (non-condensing)
Operating
10% to 90%
Non-operating
5% to 95%
Maximum altitude (unpressurized)
Operating
-15 to 3,048 m (-50 to 10,000 ft)
Nonoperating
15 to 12,192 m (-50 to 40,000 ft)
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
