Chargement...
Chargement...
Chargement...
Chargement...
HP Folio 13 Notebook PC - Removing and Replacing the Base Enclosure
Removing the base enclosure
Before disassembling the computer, follow these steps:
  1. Shut down the computer. If unsure whether the computer is Off or in Hibernation, turn the computer On, and then shut it down through the operating system.
  2. Disconnect all external devices connected to the computer.
  3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
  4. Remove the base enclosure screws:
    Turn the computer face down, remove the 16 Phillips PM 2.0 × 6 screws, and remove the base enclosure screws.
    Figure : Base enclosure
      Attention :
    Before removing the base enclosure screws, do not use a pressure of more than 3.0 kgf-cm screw torque for the 3 Phillips PM 2.0 x 6.0 screws in the following locations:
    Figure : Screws
Replacing the base enclosure
  1. Place the base enclosure in position.
  2. Replace the Phillips PM 2.0 x 6.0 screws.
  3. Reconnect the power to the computer by first plugging the power cord into the AC outlet and then plugin the AC adapter into the computer.
  4. Reconnect all external devices to the computer.
  5. Turn On the computer.
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
