- ${title}
Chargement...
- ${title}
Chargement...
- ${title}
Chargement...
- ${title}
Chargement...
Setting Up the Printer Hardware for HP LaserJet Pro CP1025 and CP1025nw Color Printers
Check the contents of the box
Unpack the printer
Insert the input tray
Load plain paper
Connect the power cord
Turn on power
Set up the printer
Follow these steps in order.
Attention :Do NOT connect a USB cable now. If you plan to use a USB cable to connect the product to the computer, you will be prompted to connect it at the correct time during software installation.
Step one: Check the contents of the box
Remove the product and other items from the shipping box, and then check the contents.
Step two: Unpack the printer
Remove all the orange shipping tape and the packaging material from outside the product.Figure : Remove packing tape
Recycle or discard the packaging materials.Figure : Recycle or discard the packaging materials
Raise the print cartridge door, and then remove and discard the two orange packing clips.Figure : Remove orange packing clips
Remove the instruction sheet.Do not turn on the power or install the product software, yet.Figure : Remove the instruction sheet
Step three: Insert the input tray
Close the print cartridge door, and then remove the input tray from inside the product.Figure : Close the print cartridge door and remove the input tray
Remove the input tray from its packaging, and then flip the tray.Figure : Remove packaging and flip the tray
Insert the input tray, and then raise the output tray extender.Figure : Insert the input tray and raise the output tray extender
Step four: Load plain paper
Video of loading paper
The following video demonstrates how to load paper.
Slide the paper length and width guides to their outermost positions.
Load plain white paper in the input tray. Slide the paper forward until it stops.Figure : Load plain white paper
Remarque :
Do not overload the tray. Make sure that the stack of paper fits within the tray and is no higher than the top of the guides. -
Slide the paper length and width guides inward until they stop at the edges of the paper.Figure : Slide paper guides inward
Step five: Connect the power cord
Connect the power cord to the back of the product, and then plug it into the wall outlet.
Figure : Connect the power cord
Step six: Turn on power
Press the Power button (
) to turn on the product.
Figure : Turn on power
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
HP ePrint
Options de support supplémentaires
- ${title}
Chargement...
- ${title}
Chargement...
- ${title}
Chargement...
Pays/région :
France
- ${title}
Chargement...
hp-hero-support-search
- ${title}
Chargement...
