Chargement...
Chargement...
Chargement...
Chargement...
HP EliteBook 2740p Tablet PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the keyboard for the HP EliteBook 2740p Tablet PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P0 and P1) screwdrivers
Small Torx T8 screwdriver
Parts required
Remarque :
The replacement part number will vary depending on the keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Keyboard with pointing stick - Full-size keyboard with spill-resistant design - Includes two buttons and two cables
597841-xx1 (Modified)
No
The part number will vary based on the country. Click here for a list of country specific spare part numbers.
Remarque :
Summary of instructions
To view a video demonstrating the procedure for removing the keyboard, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
      Attention :
  2. On the bottom of the notebook, loosen the three captive P1 Phillips-head screws identified with a memory and storage drive icon that secure the accessory cover to the bottom of the notebook.
  3. Lift the accessory cover and remove it.
  4. Remove the two rubber screw covers near the top right corner of the base enclosure.
  5. Remove the six 8 mm T8 Torx screws that secure the keyboard to the base enclosure.
  6. Turn the notebook right side up and open the display panel.
  7. Use a non-metallic, flat-bladed tool to lift the top edge of the keyboard and then slide the keyboard toward the rear of the notebook.
  8. Gently lift the locking bar on the pointing stick ZIF connector and remove the ribbon cable.
      Attention :
    Use care to prevent damaging the ZIF connector and ribbon cable.
  9. Flip the keyboard toward the left side of the notebook and rest it face down.
  10. Gently lift the locking bar on the keyboard ZIF connector and remove the ribbon cable.
      Attention :
  11. Remove the keyboard.
Keyboard replacement
  1. Place the keyboard face down on the left side of the base enclosure so that you have access to the keyboard ribbon cable and connector.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
      Attention :
  3. Push the locking bar down to secure the keyboard ribbon cable in the keyboard ZIF connector.
  4. Flip the keyboard toward the center of the notebook and insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board.
      Attention :
  5. Push the locking bar down to secure the pointing stick ribbon cable in the pointing stick ZIF connector.
  6. Toe the tabs on the bottom edge of the keyboard into the top cover and press the keyboard flat.
  7. Close the display panel and turn the notebook upside down.
  8. Replace the six 8 mm T8 Torx screws that secure the keyboard to the base enclosure.
  9. Replace the two rubber screw covers near the top right corner of the base enclosure.
  10. Toe the accessory cover into the base enclosure and lower it into position.
  11. Tighten the three captive P1 Phillips-head screws identified with a memory and storage drive icon that secures the accessory cover to the bottom of the notebook.
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
