Chargement...
Chargement...
Chargement...
    Résoudre les problèmes avec le  spooler d'impression après une mise à jour de Windows 10. Cliquez ici
    Résoudre les problèmes de mises à jour de Windows 10
    Résoudre les problèmes de mise à jour de Windows 10 sur une imprimante ou un PC HP – cliquez ici
Chargement...
HP EliteBook 2740p Tablet PC - Removing and Replacing the Storage Drive
This document is provided to assist in removing and replacing the storage drive for the HP EliteBook 2740p Tablet PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P0 and P1) screwdrivers
Parts required
Remarque :
The replacement part number will vary depending on the storage drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
250GB SATA hard drive - 5,400 RPM, 4.6 cm (1.8 in) form factor - Includes Mylar cover with tab, rubber gasket, and bracket
597825-001 (Modified)
Yes
80GB Solid State Drive (SSD) module - SATA interface, 4.6 cm (1.8 in) form factor - Includes Mylar cover with tab, rubber gasket, and bracket
597826-001 (Modified)
Yes
160GB Solid State Drive (SSD) module - SATA interface, 4.6 cm (1.8 in) form factor - Includes Mylar cover with tab, rubber gasket, and bracket
600464-001 (Modified)
Yes
160GB SATA hard drive - 5,400 RPM, 4.6 cm (1.8 in) form factor - Includes Mylar cover with tab, rubber gasket, and bracket
607703-001 (Modified)
Yes
Remarque :
Summary of instructions
To view a video demonstrating the procedure for removing the storage drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Storage drive from the menu on the upper left hand side of the screen.
Click here to view the storage drive removal video (right-click on the link to open in a new window/tab).
Storage drive removal
      Attention :
  2. On the bottom of the notebook, loosen the three captive P1 Phillips-head screws identified with a memory and storage drive icon that secure the accessory cover to the bottom of the notebook.
  3. Lift the accessory cover and remove it.
  4. Remove the two 3 mm P0 Phillips-head screws that secure the storage drive bracket to the base enclosure.
  5. Lift the rear edge of the storage drive bracket off of its alignment pins and slide its tab out of the slot on the base enclosure and remove.
  6. Grasp the Mylar tab that is attached to the storage drive and lift the storage drive away from its connector on the system board.
  7. Slide the storage drive out from underneath the lip on the base enclosure and remove.
  8. Place the storage drive in an electrostatic dissipative bag.
Storage drive replacement
  1. Remove the storage drive from the electrostatic dissipative bag.
  2. Toe the storage drive underneath the lip on the base enclosure.
  3. Lower the storage drive onto its connector on the system board and press down on the storage drive to secure it into position.
  4. Toe the tab on the front edge of the storage drive bracket into its slot on the base enclosure and lower the storage drive bracket onto its alignment pins on the base enclosure.
  5. Replace the two 3 mm P0 Phillips-head screws that secure the storage drive bracket to the base enclosure.
  6. Toe the accessory cover into the base enclosure and lower it into position.
  7. Tighten the three captive P1 Phillips-head screws identified with a memory and storage drive icon that secure the accessory cover to the bottom of the notebook.
Parts return
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
