Chargement...
Chargement...
Chargement...
    Résoudre les problèmes de mises à jour de Windows 10
    Résoudre les problèmes de mise à jour de Windows 10 sur une imprimante ou un PC HP – cliquez ici
Chargement...
HP EliteBook 2740p Tablet PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP EliteBook 2740p Tablet PC.
Minimum skill level
Parts required
Remarque :
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 4.4 Ah
454668-001 (Modified)
Yes
Battery (Secondary, Ultra-slim) - 6-cell lithium-ion (Li-Ion), 2.1 Ah, 44 Wh
443157-001 (Modified)
Yes
Battery for real-time clock (RTC) - Includes double-sided tape
482963-001 (Modified)
No
Remarque :
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
      Attention :
  2. Slide the battery release latch toward the center of the notebook to partially eject the battery.
  3. Lift the battery out of the battery bay and remove.
Battery replacement
  1. Toe the rear edge of the battery into the battery bay and lower the battery until it is properly seated and the release latches clicks.
Parts return
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
